03 Dodge Ram 5.7 won’t crank just one thunk
Safetygirl
Safford
I need help I have read other post but haven’t found no answers. My 03 dodge ram 5.7 1500 when I go to start it will give me one thunk noise and nothing else. I have changed the starter, new plugs and wires, new ignition switch and still nothing. The truck is getting power and I checked to make sure engine wasn’t seized so I’m at a loss because I have no DTC’s coming up.. and I’m tired of buying the what if parts as they start to drain the bank. So any help would greatly appreciated. I will try to get sound posted this evening as to the thunk noise it makes when I turn the key over
Daw14
South Florida
Have you had your battery LOAD TESTED ?
Clean the terminals and all of the ground connections you can find , then try.
just a thought ..
someone correct me if i am wrong ..
after using a Code Reader to hopefully find your issue :
you may find something like this
Camshaft Position Sensor
Crankshaft Position Sensor
HarryS
Air Force
Clovis NM
Great. That means you have an electrical issue, if the starter is good.
S
Safetygirl
Safford
That’s all these 03 rams are is electrical I haven’t been able to work in it the past week or more but determined to figure something out today
