04 Ram lift options??
moparmania
Can I get 33" tires to fit on a 04 ram 4wheel drive using just a levelingkit or do I need a lift. or can I go level kit and body lift?? I want to it right but I dont want to break the bank. I see alot of reponses say get as big as you can but i still want to get it in my garage. Also how wide of tire can i go before i rub or do i need spacers no matter what. thats a whole nother can of worms im sure. thanks
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
You willbe able to clear 33s with just a few turns of your t-bars. Welcome to the site bud.
olgraygoat
you could clear 35s with a leveling kit and a body lift..:drool:
M
moparmania
Whats a good brand of leveling kit?? I want one that gives me 3 inches if possible. are coil overs or torsion keys better and it looks like i only need to lift the front end and do nothing with the rear. ???
ramhunter9
P-Star Jeep Wrangler
If you want 3 inches just get a body lift. There is no 3 inch level out there for your truck only 2 and under.
As far as rub. As long as you get the proper rims with the offset you will be fine
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Are you 4x4 or 2x4? 4x4 has keys, 2x4s have spacers.
M
moparmania
I measured my garage height and it looks like i can do about 5 inches of lift. so i was thinking 2.5 inch level kit and 2 inch body lift. that should get me some biggin tires on and look good. is skyjacker a decent level kit? and could a guy put in a level kit for the front and add 2 inch spacers in the back or is that to ghetto? it just seem if i put a 2.5 inch level kit my front is going to be to high and im going look like a gasser from the 50's
txbass06
NE Texas
5.9 Magnum
Just make sure you take into account the size of the tires you want to put on there. If you do a 2.5" level, then a 2" body, and go from 31's to 35's then your front end has raised a total of 6"...
