1" or 1.5" BL?
Cb1000h
Does anyone know of any install write ups and best product
I have 2013 1500 4x4
I have installed many body lifts on Jeeps before and there is always some fabing to do or extending of some control rod/shifter etc..
Are the 1" or 1.5 really as simple as I have read
Are there any pitfalls I should be aware of prior to starting besides the exhaust being low and needing a tweek
Also will be running 2.8 Bils and 1.5 or 1.75 spacers and Bils o
Thanks
Wayne
akra11
Kitchener, ON, Canada
2016 Laramie Limited Crew Cab, 8 speed
5.7 ltr Hemi - 8 Speed; T1000 Diabolo - Custom Hemi Tune
Have a 2014 ccsb with 2.8 bils front and ITEC progressive coils in back, interested in any responses as well
Sent from my SM-G530W using Tapatalk
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
I installed my Zone 1.5" body lift on top of my Zone 6" suspension lift and am really happy with it! The only "modifying" we had to do was cut a section of the rear bumper for my hitch in order for the new location of the rear bumper to fit properly. Everything else was pretty simple but I highly recommend having at least two people (including yourself) to do the install.
Adam
C
Cb1000h
Any welding on the 1.5 BL for Ram
Yeh I figured it would be a three man team
Took about that for the jeep which is a 1" BL had to drop the radiator and cut a bigger shifter hole as well as weld on supports on a 4" plus and spring over axle
What a blast that was
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
No welding or any other modifications other than what I said.
Adam
Jameson
Fort Benning, GA
I believe sport models are little more involved BC you have to take the headlights and grille out. Maybe I'm wrong.
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Had to do the same for mine....
picture.php
Adam
J Rod
Ft. Wayne, IN
Yes it is a piece of cake, no welding.. Other than swapping in the blocks and new bolts you'll have to cut a small notch out the rear bumper, drill 2 new holes in the frame for the front bumper, and readjust your exhaust tips... that's pretty much it. I did mine by myself as well, only part where I could've used a second set of hands was reinstalling the bumpers (the front bumper especially). I ended up using a jack and a 2x4 to lift it up and hold it in place while I guided the bolts into the holes, it actually worked out fairly well once I got the hang of it.
Reticle918
