12v Outlet not working
NoveskeFan
Historic Triangle area in VA
2017 Crew Cab Short Bed Copperhead Sport 4x4
The center console 12v DC outlet stopped working in my 2013 Ram, I did have the truck running when trying out a few different chargers in the outlet. The rear outlet still works. I might have shorted it out the other day when I plugged in an air compressor that had a frayed wire I didn't know about.
Is there a fuse for this or do I need to replace the outlet?
RodRam
Ga.
fuse box under the hood, front and back are seperate + you can move the rear socket fuse one slot over it has two and it will work with switch off, its in the owners manual
NoveskeFan
NoveskeFan
Thanks all! I'm at work and won't be able to check it until this evening or tomorrow. I'll update with what I find.
