13+ TYC Projector Questions
2014moparam
3.6 V6
Ok. So.
About a month or so ago, I retro'ed a set of ebay headlights. Turned out great, but there are two major flaws.. Condensation, and the cutoff isnt straight, and there is no way to adjust it.
Im SERIOUSLY debating taking the plunge and just going the route of the replicas...
Obviously I will need the lights, adapter cabling, and bulbs for my current hid setup.
What size bulb do those take? Is adjustment done just like the factory quads, through the hole in the fenderwell?
2014moparam
2014moparam
3.6 V6
Plunge taken.
Oh boy..
Ordered the black projectors, adapter harness, and a set of the HIR2 5k bulbs.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
TY for your order! we'll get these out the door with FedEx tomorrow!
2014moparam
2014moparam
3.6 V6
Thanks dude! As far as install goes, presumably plug and play, minus one or two ground wires?
1500ram12
5.9L Cummins
If you are just adding the tyc projectors and no hid's, I believe that there is a difference between the 09-14 adapters and the 15's. I bought the 15's specific one's after my little mishap and they had 2 resistors per side compared to the earlier version I had which only had 1 per side.
Sent from my SM-N910V using Tapatalk
2014moparam
2014moparam
3.6 V6
As of right now I have the DDM canbus hid kit with h1 bulbs in spyder headlights. With the tyc headlights, I ordered the lights, 13+ harness, and morimoto 5k bulbs. I'm going to the-use my DDM kit and use the Morimoto bulbs with it
2014moparam
2014moparam
3.6 V6
So heres a question, either for JJ or for anyone else.. I have the DDM hid kit installed right now, which has the resistors built into it for the bulb out warning message.
The harness for the 13+ i ordered with the TYC lights appear to have two resistors, one for the hyperflash of the turn signal, and the other for the bulb out warning message?
Is that going to mess with my hid kit that I already have? Should i connect both resistors on each side, or just connect the one for the turn signal?
Just trying to make sure I know everything before I do this install...
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Sorry about the delay, but got ya cared for via email ;) TY!
2014moparam
2014moparam
3.6 V6
Scheduled to be delivered tomorrow! Hopefully I can con the wife into parting with me for a while to install them lol
Seriously geeking about these haha
KWG88ss
Pennsylvania
Let me know how it goes: Just picked up an 18 Big Horn and the only thing I wanted to change was the reflector to a projector HID setup.
Reticle918
