If you click the link you will see the coolest grey truck ever in the customer picsI think these are the same and I like them a lot
https://www.suspensionsuperstore.co...2wd-4wd-premium-2-rear-lowering-coils-272920/
Mine stayed the same. Didn't measure,but look the same as it did. Even on both sides. Only thing I've noticed is with a full tank of gas it's about 1/2" lower on drivers side than the right.
l--my only problem is harder to see out of rear view mirroe
With the 2 inch drop at the rear it is harder for me to see with the rear view mirror--the the roof line has dropped down and unless I slouch down in the seat sometimes I cannot see as far back as I used to---I am 6'6" and have that same problem in my older toys--used to be able to get a lower styled mirror or manually drop the mirror to helpHow so tb55? I did not notice that, but wasn’t’t looking for it either. Curious.
T.
I installed the maxtrac 2” rear drop springs on my 17 cc, and noticed a vibration at about 35-45mph. Took them off and vibration went away. Anyone else have that issue?
No vibes here. I bought the Amazon ones. You might want to check your rear end geometry. Mine is posted above. How many miles on your truck? I only have 29k
