2003 Cummins 47RE Trans - Which ATF?
Stoffregen Motors
Cool, CA
5.9 Cummins
Hi all.
Getting ready to do a trans service on my 2003 4x4 and I can't for the life of me, remember which ATF I used last. I have a gallon of Valvoline synthetic AFT+4 in the trailer labelled "Dodge Trans", but I don't recall using that.
The trans in my truck is built, meaning it has two different shift kits, a heavy duty GM shift solenoid, deep aluminum oil pan and a billet converter. And I do haul heavy loads.
So what ATF are you guys using for heavy towing?
tjfdesmo
AZ
Should be ATF +4 unless your specific mods require something different, which is unlikely.
HemiLonestar
Navy Badge Coast Guard
MD
What does your owner's manual say?
Stoffregen Motors
Stoffregen Motors
Cool, CA
5.9 Cummins
Right. ATF+4 is the recommended fluid from new. But I was wondering if you guys had any thoughts on alternate fluids.
I had a schooling a few years ago by my transmission rebuild guy. When I asked him which fluid to use (in a different build) he gave me a quick lesson in ATF. It's basically new vs old. The fact that there are so many different specs from OEM is a joke.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
NEW off the shelf components like friction clutches, are made to use the latest version of the OE fluid. If your trans was recently rebuilt it will use ATF+4 for the application. Plus, the +4 supersedes the prior versions.
Using anything else is experimental and may affect the life of the friction disks.
Ghstrdr95
