Redtruck-VA
- Jun 29, 2010
- 5,864
- 985
- Location
- Virginia
- 2003 & 1989 D250 RWD
- Hemi-5.7, 5.9 12v & 24v diesel
Since this comes up occassionally I thought I would post it,
Take off the 1B cover and you will see the Yellow and green wire going into the plug. With a small scket set lossen the bolt in the center and pull the plug away from the Computer. Locate the correct side where the Yellow and green stripe wire is and then Pry the RED retainer out and using a jewelers flathead screwdriver and push the wire out the backshell and pull the wire completely out.
position the wire out of the way and reinstall the red retainer and plug...
If anyone has pictures to add, that would be great.
