2009 Ram 1500 5.7 Cam Pin Sheared Off
jws123
nj
I just picked up a cheap 2009 Ram 1500 5.7 170k I was told the camshaft pin for the gear shared off sure enough it did. I assume someone installed a cam at some point and didn't tighten bolt I don't see any other major engine damage with the borescope in cylinders. I am sure it has a few bent valves ect is the pin part of the cam or can I drill it out and replace it? If so anyone know the part number or where I can get one?
Thanks.
jws123
jws123
nj
Anyone? not having any luck finding a new pin local dealer was useless as well.
Daw14
South Florida
What about a cam manufacturer,like crane . Or maybe summit parts
jws123
jws123
nj
I emailed summit waiting to hear back but I don't even know the size of the pin so that doesn't help.
Daw14
South Florida
start working on removing the pin ,maybe if you get it out you can get a measurment if it’s not to messed up .something likely caused a sudden stop of rotating components .im interested.
WY.Ram
Larkspur, CO
6.4L Hemi
I still have my oem cam I pulled with the pin still in it. If you haven't found o e yet, I can pull this pin and its all yours. Measure it, use it, melt it down for a premium reload, it's all yours. It'll take me a couple hours but them I can break loose and go check out what's there.
Heck with it, my current task s.u.c.ks, I'll go grab it now and send at least some photos.
jws123
jws123
nj
Thanks I just ordered one from summit that I 'think' is right guess il find out if it doesn't fit il message you for sure.
Also I don't see any evidence of bent valves somehow.. going to throw er together when I get pin see what happens crossing fingers.
WY.Ram
Larkspur, CO
6.4L Hemi
Really? Is that even possible, even for the luckiest of them (not me)? I always assumed major catastrophic failure if the shafts spun out of time. I don't disbelieve, I just know I would be picking a fair amount of my engine out of my crankcase.
But that's bada$$ if it's all straight.
Glad you found a pin, it didn't feel like this one was coming out in one piece. I even tried a little heat on it.
But there are the dimensions of an oe pin, you can verify your order.
Post back if she fires up, actuay either way, dying to know.
DILLIGAF
Canadian Forces
Canada
If the pin sheared off you bent pushrods.
jws123
jws123
nj
While I agree this is how it should be the Push rods aren't bent I looked lol I just had a similar thing happen with a high mileage 3rd gen 5.7 it lost its chain replaced it and it ran like nothing happened. I have no idea how maybe it fell off on startup before lifters pumped up? probly will never know its starting to look the same on this one I am guna record when i start it up!
jws123
jws123
nj
Thanks that's very helpful looks like the pin I ordered is very close
jws123
jws123
nj
Somehow got the old pin out :D drilled and tapped it little heat and it came right out although i drilled a hair to far waiting for new one to come hope it fits.
jws123
jws123
nj
did you buy 100 lol?
Yes I did lmao other places where going to take to long to get I got these in 1 day for $35 so worth it In my mind maybe il sell some on ebay if anyone needs cam pins HMU :laughing1:
RLJ10X
Southern Indiana
I don’t know if this is applicable, but I work on guns a little, and if there is a missing pin, quite often a piece of drill bit shank can be used. Drill bits are usually a precise diameter. They’re hard. Just have to grind them to the proper length. Works in a pinch.
James OBrien
St. Louis
5.7 Hermi
Beat me to it, I had the same problem this gentleman describes but I sheared my pin when doing a cam install and trying to test for interference; didn't have the crank bolt tight enough! Used a drill bit shank like you advised and it's worked well!
Sur5er
NY
IME, almost all cam pins are press fit. Pull cam and see if the hole is thru or blind. If blind, you can A: have a bud with a MIG/TIG weld an extension on the pin and pull it out or B: back drill the blind hole an punch it out. Apply heat sparingly! Good luck.
Dusty
Rochester, New York
Check your cam phaser.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33 gallon fuel tank, factory dual exhaust, 18” wheels. Build date: 03 June 2018. Now at: 062731 miles.
