SalvageRam
My 2012 Ram 1500 5.7 liter Hemi has a front differential leak, and I need help pinpointing where exactly it's coming from. In the pictures provided, you can see that there is a small and slow leak on the front diff where it connects to this second half of the front diff. Not sure what its called exactly:
Just by smelling it I can tell its gear oil. Has that sulfur like smell. I ran my hands all along the top of the differential, and there's no gear oil leaking from there, just dust. Also, where the driveshaft connects to the front diff is dry, as you can see in this picture.
The previous images are from if you were looking at the diff from the rear of the truck. Here are some images from the front just to show that the fill plug, the drain plug, and the areas around it are also dry.
My best guess is that where these two parts of the diff meet, there may be a part of the gasket that's failing. Here's an image of some excess gasket material that was squeezed out when it was first installed. It does feel slightly moist in this area.
Back:
Front:
Here are some conditions that I've been able to figure out. This seems to happen after the car has been driven for a little bit. Usually if I drive it around the block a couple of times and I come back to the garage, there will be a drop or two under the diff. This does not happen just when the car is started and in park. It happens after it's been driven. If I leave the car in drive or reverse while stationary, the leak does not happen. The leak is slow and a few drops. I have not tested putting it in four-wheel drive yet. But if anyone thinks that's necessary to do, I'll try it out.
So my questions are, where is this leak coming from? Has anyone on this forums seen this type of leak before? If it is what I think it is, how involved is repairing it? The rear diff is pretty straightforward in that you just take off the cover, clean and reseal. But the front diff isn't as straightforward. Any and all help is greatly appreciated.
