2013 air lift springs. Which model #
smiley87
Alaska
5.7l hemi
I want to add the air lift 1000 kit to my new 2013 ram 1500 but every website says it won't fit 2013. Anyone got a model # for the kit that works?
joeg45
Katy, Tx
Like he said but heres both
Normal ride height PN: 60818
If your 2/4 dropped PN:60824
Thats whats used on all other rams i dont see why it would be different but then again never seen one up close
S
smiley87
Alaska
5.7l hemi
I'm looking for some to help stay level when towing
S
smiley87
Alaska
5.7l hemi
Did they change the springs in 2013? Amazon is saying these don't fit 2013
jlb
MT
CTD
Keep in mind the 13 ram can be ordered with the auto leveling etc stuff. That could very well mean that they changed the whole design to accommodate the modified air setup...
I wouldn't buy anything until someone can confirm the design hasn't changed for your truck.
Why don't you post up some pics of your rear suspension setup as well as the dimensions of your coils when the truck is at rest.
Coil diameter, coil height, number of links. That should do it. As long as the bags fit inside, and the number of links is the same the ones I have on my truck, Airlift 1000 series should work fine. That is what a lot of people on here run.
As a note, it is easier to get to the coil on the left hand side of the truck.
S
smiley87
Alaska
5.7l hemi
As soon as it is warmer I will post some pics. Right now it's about 18 degrees out ad my truck doesn't fit in the garage
