2013 STL power steering stopped working
imon2u
I have a 2013 SLT 1500 that we purchased used about 2 years ago it currently has 67k in miles. The power steering has ceased working. I get a service power steering warning on the dash when it first happened I turned the truck on and off a couple of times and it worked to get me to town then on my return I had to repeat the process.
Yesterday that did not work and no power steering. I did find a loose negative cable on the battery removed and tightened but still no joy, I tried removing the positive cable to see if maybe the loose negative cable caused an issue and to clear out anything in the system still no joy. I read there are two fuses for the EPS but I did not get the owner's manual for my Dodge when it was purchased and the online diagrams I find do not mention the EPS fuses would anyone happen to know which two fuses I need to check?
To replace the Rack is a little over 2k so looking for anything I can check before paying a tow bill to find out it was a fuse or $20 fix.
There should be a 100 or 125 amp fuse bolted practically right to the positive battery terminal for the power steering, It's a Z-Case fuse(see pic)
The other fuse I think is F78
turkeybird56
Central Texas
https://www.moparpartsinc.com/p/Ram...MIrujOupXo5wIVUfDACh3rUQHwEAQYASABEgIlovD_BwE
Uses fusible links (but confirm, do not take my word on it).
But I am no mechanic. I had the Zcase's on my ED, the 5.7 are a lil different. There are no Z-Case attached to positive cable at battery. One goes direct to Master Fuse case and another branches off somewhere down towards electric power steering unit, Cannot see where,.
NOTE: I have a MY 19 5.7 Hemi, No friggin E-torque truck. I had a 2015 ED with the Z=-cases on the battery terminal.
I do have a Battery Temp Sensor attached to my "negative" cable.
turkeybird56
Central Texas
I heard somewhere, that when yer EPS goes out, U now have what used to be called: "Manual Steering" ??? lol :joke:
Used to drive an old school bus converted to a Church Bus, and dat Puppy did not have Power Steering. My 67 Chevy Impala SS did not either. No need to go to the GYM in those years.....
I
imon2u
It was not either Fuse so most likely the rack will need to be replaced unless it is an issue with the U joint on the steering linkage. Thank you for your assistance and thoughts. I am able to turn the wheel even at a stop but as we have a farm and the wife won't haul hay in her Kia I will have to get it fixed so it is safe for all to drive. My then 5-year-old Grandson saw the truck and said to my wife who he calls G Paw Paw has to have this truck. His thought is one-day Paw Paw will give it to me.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
203671507
203671509
MODULE-EPS C1
Harness Family: EPS_Jumper
Cavities: 3
Color: BLACK
Gender: FEMALE
Part Description: 7287-0955-30
Engineering Name: Mod_EPS
Connector No: D2777A
Option: Standard
203443824
Pin Circuit Wire Color Gauge/Size Function
1 D139 YL/BR 20 CAN C (+)
2 F942 PK/LG 20 FUSED IGNITION SWITCH OUTPUT (RUN-START)
3 D138 YL 20 CAN C (-)
MODULE-EPS C2
Cavities: 2
Color:
Gender: FEMALE
Part Description: 7287-1990-30
Connector No: D2777B
Option: Standard
203443828
1 A950 RD 20 SWITCHED B(+)
2 Z926 BK 20 GROUND
