2014 2500 Ram 6.7 going on 4th trans in 5 months? Dealer now tells me its tires?
SRich2015
USA
Nice what gear did you go with how do you like it.
4.10's My 2012 2500 had 4.10's and I loved it(should have kept it) IMO I think they are the best gear behind the cummins!!
JD Mark
6.7, 6.4, 6.7, 5.9 in a F750
Any time you have a trans go out from debris, at the very minimum you need to flush and clean all lines involved. After 2 of them in short succession, you pretty much have to replace all lines and coolers involved. Sometimes this means the radiator too. If the dealer isn't doing this, then they're actually CAUSING the problems at this point.
Bingo!!!
JD Mark
FCA is saying you broke your tranny and were not gonna fix it anymore.. Welcome to the FCA paper warranty.
Except they have to prove the tires were the cause.
TMFMK
