2014 Ram 1500 8 speed transmission “spike overheat” - discussion
Huxrules
Houston, TX
Hello, first time posting to this board, I have a situation that has happened twice now that I think could potentially indicate a failure mode with the 2014 Ram 1500 8 speed transmissions cooling system. I call it a “spike overheat”. What happened to me is that I was driving along I-10 in Texas at 80 mph (the speed limit actually) and the transmission temperatures dramatically began rising. In this case the transmission got to 230F before I found an exit and pulled over. As other posters have noted the solution is to let the vehicle sit and cool and once the transmission gets back to normal operating temps you are fine. I knew this, of course, because I am actually on my second thermostatic valve and transmission oil cooler. I knew also, that once a spike overheat happens that you have broken the thermostatic valve and it will continue to happen until its replaced.
I have had a lot of trouble with the transmission on this truck. It was actually replaced by Ram at 40k (approx) because it was shifting hard, stopped going into reverse, and eventually ended up in “limp mode”. Interestingly I was told by the dealer to let it grenade before sending it in, but thats another story. They did not replace the cooling/heating system (I think). About 10k miles later I was driving my truck on, you guessed it, I-10 going 80 mph when to my horror I looked down and the temperature was 246F. This was near Bandera, I limped it back to Houston with spike overheats occurring probably four more times before getting it to the dealer. At the dealer I was told the bad news, the thermostatic valve had “broken apart” and pieces were in the transmission cooler, potentially blocking flow. Total cost something like 1600$. I fought Ram but caved and had the system replaced. It was fine until three days ago (about 30k later). The exact thing happened, amazingly near bandera/I-20 intersection.
I haven’t taken it to the dealer but it is acting exactly the same as before. My hypothesis is, in this particular failure mode, the thermostatic valve has destructed, the heater doesn’t work at all during warm up, then when its time to actually send transmission oil to the cooler it actually sends it to the heater. The observation that I have had is that the transmission is slow to warm up, taking thirty mins on the highway, the transmission can stay happily around 183-190F on the highway for several hours. The transmission becomes stressed at some point, say climbing hills or traffic and once the temperature reaches 194F, it’s off to the races. With the oil potentially being heated instead of cooled it quickly reaches an overheat (like ten minutes or so).
I think the overarching warning here is to watch your transmission temperatures if you drive on long trips often. Unless you are actually looking at the numbers on the transmission temperature page or the gauge summary page you will not notice it. I’m guessing there are hundreds of ram trucks out there with broken thermostatic valves that spike overheat constantly and the driver is none the wiser. I have yet to see a code or warning light, and the side gauge doesn’t move much, even at 240 deg.
I have no ides what the causes it- I have been driving a lot from Houston to Tucson. This includes a stretch of highway that is 80 mph from Kerrville almost to El Paso. It’s long, like a tank of gas long. By my records the thermostatic valve initial failure happened on the fourth round trip, both times. Causation doesn’t equal correlation, but its suspicious as this stretch of highway is unique to Texas.
I’m going to try to get the transmission to overheat on the highway here by simply running it at a lower gear at speed (like climbing a hill which we don’t have in Houston). It’s probably a bad idea but I’d like to show if its repeatable. Then I’ll take it back to the dealer for a fight.
Sorry to hear your troubles, the 8 speed has been a popular choice for the transmission on the forum. I can't make heads or tails of what is going on, sounds like you got a lemon for sure. All I have to offer is that the 8 speed transmission is mechanically heated, if it is taking 30 minutes of the freeway to get to 190-200F, I would say that can hint an an issue. I would also say that 230f is a normal operating temp in a lot of the 8 speeds. I wouldn't worry till around 250f. Many operate lower like 190, but many many also operate at 220-230f. The 6 speeds operate like 135-140f.
Do the gassers run that much hotter? (or is caused by the GO pedal? lol)
Even towing 8000 lbs in 85°F weather mine never broke 200°F even with 220°F coolant. Normally it's 185°-192°F which is the higher range of what I've read about, there are some run in thehigh 170°F. Any of the transmissions that I've read about with temperature issues will run higher than the coolant temp.
Pettybilt
I have a 15 5.7 with the 8 speed.
Had my trans replaced around 25k miles. It had a 1 2 flare, and the tech noted the fluid was burnt.
So now the second trans is junk also.
Still have the 1 2 flare, at times a down shift fills like I got rearended cause it shifts so hard. And now it whines going down the highway.
All this is normal according to FCA cause it doesn't have any check engine lights.
First and last Ram for me, FCA totally sucks when it comes to standing behind my truck.
Can't wait to get rid of this truck.
My trans hit a record a few months ago with the wife and kid.
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
I dont think mines ever went over 195*, even towing in the summer it stays cool.
It does suck how FCA does not seem to stand behind their products unless you have a great dealer.
Arth
2022 Ram 3500 Crew Cab Limited 4x4
6.7 HO Cummins Turbo Diesel
Interesting. I've owned a few 2013 and 14 Ram's all with the 8 speed and they were pretty consistent. 185-190 once warm and would run anywhere from 180-195 on long highway runs.
This is just me talking but a sudden spike in temperature couldn't be related to improper amount of fluid could it? I know these transmission are a little harder to fill with no dip stick and all.
I know of three transmissions that had spiking temperatures and they were all fixed when the transmission heater assembly was replaced. With one of them, the owner paid to have the heater assembly himself. With the documentation of the temperatures before and after replacement, FCA eventually ended up reimbursing him for the repair.
Arth
Heater assembly... are you talking about that in line T-stat that is supposed to control when fluid is supposed to be let through?
The heater assembly is on the side of the transmission with the coolant lines running to it. It also has the thermal control valve(bypass) that controls the transmission fluid that goes to the top of the AC condenser.
As far as I know, you have to replace the entire assembly. There's a company that custom builds 8HP transmissions that offers just the bypass but they will only sell it to you if you have one of their transmissions.
Daniel Ortiz
Houston, TX
5.7 L Hemi V8
@Huxrules,
I'm also from Houston, TX, and what first happened to you just happened to me. I had it in +/- 8th, cruising down south to Brownsville, when I casually looked down at the gauge summary and saw my transmission at 230 F (coolant and oil temps were normal). At steady state on the highway it normally stays rock-steady at 185 F, so this was GREATLY alarming. I pulled off the highway into a truck stop, and noted that as I was slowing down, some of the down shifts were kind of jerky, which has never happened before. Even as I was slowing down I saw the temps start to fall. I parked it, got out and took a look under to see if it was leaking transmission fluid, and it was bone dry. After sitting parked for about 15 minutes, the temp was back to about 185-190 F. Not knowing what else to do, I got back on the highway, leaving it in 'D' this time instead of "+/- 8", and the temperature actually ran cooler than normal at 181 F until Kingsville (2 hours away) where I stopped for lunch. From Kingsville to Brownsville, another 2 hours driving in 'D,' it rose back to 185 F and held there like normal.
So, I've been looking for information on this forum, and I found your post. It's kind of amazing. Unfortunately, the remainder of your post fills me with a little dread. I'll keep a close eye on that transmission temperature on my way back to Houston. I'm hoping I didn't break anything. We'll see.
Have you had any new insight into this issue you had?
Daniel Ortiz
Houston, TX
5.7 L Hemi V8
Update:
After driving back to Houston from Brownsville, and around town Sunday evening and all of Monday, whether I keep it in 'D' or "+/- 8th," the transmission temperature slowly rises to 185-186 F, sometimes getting up to 190 F if I'm doing a lot of slow down/speed ups (this was normal before my trip described above), but otherwise nothing abnormal.
I wonder if driving in "+/- 8th" over long extended periods on the highway is not good for the transmission, for some reason. I don't know what else it's doing to the transmission programming aside from keeping all eight cylinders firing all the time, but apparently it does something. Has anyone else noticed this transmission temperature spike when driving for a long time in this mode?
The +/- buttons is the Electronic Range Select (ERS), it's no different than the transmission in D with the exception of the MDS being shut down. Unless the trans temp is going above the coolant I wouldn't worry about the temperature. It's possible with the MDS off that your heat soaking the engine compartment more causing the cooling to react differently. The AGS may have to open more for engine cooling in turn the TMU is flowing more trans fluid instead of going through the AC condenser cooler.
