2014 RAM 1500 Express Crew Cab
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
1.6 years with the Clayton 2.5" springs. they don't sag :). 1.8 years with the Clayton rear control arms, zero issues, not a single noise, don't have to grease chit in them don't have to even worry about they exist back there. 110k miles on the truck now. Damn.
51631664923_f51026e5dc_h.jpg20211026_113157 by RAM RSM, on Flickr
crazykid1994
View attachment 47534220211026_113157 by RAM RSM, on Flickr
I can’t find it now but how much lift did those rear springs actually net you? Looking at upgrading from my rear eibach springs to a longer spring so I can get rid of my rear spacer. Not looking for a ton of added load as I like how my eibach feel with my truck setup but want something longer unloaded for my rear shocks.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
2" with about 400-500lbs extra weight.
crazykid1994
So it’s actually pretty close to specified lift for the ram as well. Interesting. May look at the icon gladiator rear springs. They’re 1.5” lift. I’ll have to message icon for free length and see if they’ll release spring rate. I’ll have around 300lbs constant weight in the rear between my rear bumper and tire carrier I have planned and my tonneau cover. I plan on adding a water tank as well in the spare tire location. Debating somewhere between 12-20 gallons so 100-150lbs more but not full time. Hoping to drop down to around 1-1.5” rear lift instead of 2”. The extra weight will probably do that but I’d also like to get rid of my rear spacer. I need something around 20.5-21” free length though because I’m running the longer bilstein 5160
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Unfortuantely Icon doesn't disclose anything that relates to specs on anything they make. I couldn't get them to tell me something as silly as their spring free length on the Icon 1.5" RAM springs, but you'll find that info in the excel spreadsheets i have posted in the lifted section somwhere. The admins around never added the post to the stickies, not sure what else is needed to do something like that, hint hint to the mods ? any mods around ? Lol
Clayton JT rear 2.5" springs will lift a stock crew cab 4th Gen RAM 1500 2.5"
Will do 1.5" more on a stock 5th Gen RAM 1500 with ORP
Claytons COR-1510251 have a 21.5" free length, The Icon specific RAM 1.5" coils are 19.5" long
Clayton spring triple rate : 159lbs 1st, 280lbs 2nd, 360lbs 3rd rate
You also have the Synergy 2" JT rear coils that @hodge-xj is running
Synergy 8865-20, they're 20.375" long (measured by hodge), dual spring rates, 165lbs 1st, 250lbs 2nd
If you need more they have 2,3,4 and 2.5 3.5 and 4.5" springs
Or you can try rear JT springs from any manufacturer there is out there, the sky is the limit now for us when it comes to rear springs, or rear control arms, or rear trackbars, anything from the rear of the 2020 JT when it comes to this parts should be literally a direct fit for us. the only difference in the springs is the upper portion of the JT spring is wider so RAM specific rear upper spacers won't fit. lower is the same as ours.
In contrats to for example BDS 3" linear springs, they have a 240 ft/lbs rate, and are 20.875" long.
Have fun.
crazykid1994
Those synergy springs look nice. May end up with those. 250lb per inch too. That’s probably right where I need it for the weight I’ll be adding. Should net me 1.5” lift when loaded And should work with my shocks. My shocks are 27.6 inch extended length
hodge-xj
5.9 cummins
Every time I see you post pics of those clayton bits I just wanna spend all the money. Once I pay this thing off I think it'll be time to treat it to a bunch of nice fresh parts
Treburkulosis
Your High End Detailer
Haslet, TX
Its in the 80s here in Texas as well. Not hot tho thank goodness. What are you going to get next?
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Plan was to get a skid for my bumper from the same manufacturer. Which i see have they posted 10% off today to honor their Black Friday sale.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
I did some testing thinking to help the community on a thread we had running last year where we were discussing where to put the flexy joints from your rear control arms, frame or axel. I said Frame, somebody say axel, we went back and forth but we never concluded anything.
So yesterday i was doing some testing on my Jeep front Antirock setup
51693725071_a6cd0cc684_h.jpg20211120_123229 by RAM RSM, on Flickr
and i took the opportunity to observe what the rear control arm bushings were doing and that thread we had here came to mind, so here are the results from my observations. You want your flexy bushings on the frame (assuming you have arms with clevite on one side and flex bushings on the other side), In this case we were discusing Core4x4 T3 arms, if you have Claytons or any other arms with flex bushings on boths sides it wouldn't matter, if you have JJ on one side and flex bushings on the other put the JJ on the frame as the the bushings at the frame do most of the flexy work.
So to save time from the entire read this is a copy and paste from my post#43 there
"Hi Red. bringing this from the past to show you where the bushings put out the flex. I was doing some testing today with my Jeep and the bushings happened to be there to show me how they react to one wheel drooping so i thought about this thread :)
20211120_123420 by RAM RSM, on Flickr
20211120_123257 by RAM RSM, on Flickr
My lowers arms are all Clayton overland+ with the Giiro bushings, the uppers are factory clevite.
So with one wheel droop:
Rear lower at frame side, look at how much that bushing is doing the work.
20211120_112547 by RAM RSM, on Flickr
Rear upper Frame side, the lowers flex a lot more than the uppers but even then look at how the bushing is binding a little since clevite doesn't twist side to side like flex joints do
20211120_112431 by RAM RSM, on Flickr
Now lets look at the axel side
Rear lower at frame side, there is a little flex there, but it's not the same as what we see in the frame. I'll say it's virtually nothing in there.
20211120_112637 by RAM RSM, on Flickr
Rear Upper axel side, little flex as well.
20211120_112420 by RAM RSM, on Flickr
The stock rear shocks on my Jeep were 22 1/8" extended, the current rears are 26" so they're literally 4" longer than stock. I'd think this is why mostly every other manufacturer out there with rare exceptions put the flex joint in the frame side.
Sorry it took me a year to be bothered enough to do the test :)"
RamRodJay
Tucson, AZ
Been following your build for a bit and found some inspiration here and there.
For what it's worth, Im running synergy's 3" rear spring on my 1500, have had them on for about the last 5 months, no sagging thus far. RTT and a good 200lbs combined worth of gear in my ramboxes. 40.5" ride height on passenger side, just a hair under 39.25" on driver side. Still on 265/70/17 Pat's that have about 5k left of life on them, have a set of 35's Kenda Klever RT's sitting here waiting to be installed.
I do have that typical 4th gen lean--guessing a spacer will fix that? I dont have the control arm or panhard bar upgrades (yet). School has wrecked me this semester and just havent had time to order/spend the money much less find the time to install with everything else going on.
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Glad to be able to help our community and inspire some builds.
A spacer on that side where you have the lean will fix your issue right up.
Ebay has some 1/2" rear spacers for the RAM for example
RamRodJay
Tucson, AZ
Can confirm, toss in a spacer and load it heavier to passenger side.
So, question on the spacer aspect. You had mentioned a half incher.
Since im roughly ~1.25" sagging on the driver side (measurement was taken around a half tank of gas, assuming itll drop a smidge with a full tank), should I be aiming for a 1.5" spacer, 1" spacer or .5" spacer to level it out somewhat..
I can definitely shift some weight/heavier gear over to the passenger side, but not a whole lot more
ram1500rsm
ram1500rsm
Trabuco Canyon, CA
Measure with a full tank all 4 corners to make sure before you get the spacer.
1" spacer
1.5" spacer
RamRodJay
Tucson, AZ
So topped off the gas tank completely and here's what I got (measuring from ground to top arch of wheel well) ..keep in mind, my newer tread tire is on the passenger front currently, so circumference may be adding a hair or two to measurements:
LF - 37 21/32
RF - 38 13/32
LR - 38 23/32
RR - 40 19/32
So in other words, I have ~ 3/4" lean on the front towards the driver side and ~ 1.875" lean on the rear driver side (full tank of gas)--which would also explain the ****** off girlfriend every time she hops in the truck haha.
Im guessing a 1.5" spacer tossed in the rear driver corner will level it out (still would have ~3/8" lean but i can live with that/still load the passenger side of the truck heavy to compensate.
Does that sound correct?
brendo99
