If at the rear of the Radio, there is a Speaker Port
find a microphone with a male plug that will work.
Instead of paying a ton of money on the lousy
non noise cancelling microphones that is part of the mirror,
buy a Noise Cancelling microphone with a longer cord.
choose one of these two locations to clip the microphone head to
the first place is on the drivers "A" pillar, remove the pillars cover, run the wire up the windshield side of the pillar, to about eye level. put the cover back on, leaving the microphone head between the pillar & the windshield
The second place would be again using a long cord
run the wire up either of the "A" pillars & then over to the overhead console
Remove the over head console enough to work the microphone cord & head, to a point on the left side of the console that is approximately 6" or a bit more in front of your right eye,
the microphones head can be pinched a bit,, between the console & the roof liner
some ideas, you may find one that is slimmer & still efficient
RAJAVIP adalah platform resmi yang dikenal sebagai link raja game online terbaik, menawarkan pengalaman hiburan digital seru dan dijamin pasti approve.
whatcarneeds.com
The reason that i brought up the change of location for the microphones head, is because:
The stock mirror microphones are not noise cancelling
the breeze from an open side window has to be closed, or the Fan from the HVAC System has to be turned down, when you use the hands free microphone.
If you doubt it, look in the Owners Manual, it tells you to roll up the window & turn the HVAC fan down to the low setting !
They know they screwed up
