ramffml
- Jul 12, 2019
- 2,832
- 5,222
- Location
- ramforum
- 2019
- hemi 5.7
Vern, the reason why gears is a waste is because you can get the same effect with a downshift. We have 8 speed transmissions now, and if you do the math you discover that 3.21 is just 1 gear ahead of the 3.92, but both rear ends end up having almost identical gear ratios for the 5 main highway gears, just offset by 1 numerical gear (so 5th = 6th, 6th = 7th, and 7th = 8th etc).
Different story in the old days with a 3 or a 4 speed, but with todays 8 and 10 speeds it's a waste of money unless you're making a very large jump like 3.21 to 5.xx
You don't necessarily get anymore torque from a gear swap: RPMs are RPMs, and gear ratio is gear ratio. If you're driving the same speed (3.21 vs 3.92) and both trucks are at 3000 rpms, then both trucks are putting down the same amount of torque (because the gear ratio is the same, regardless of the numerical gear number you are in). All you're doing is moving the gear ratio to a lower numerical number, meaning, if you didn't swap and instead downshifted, you'd be in the same position. So it's like rearranging your tranny such that your gear ratio "X" which used to be in 5th, is now in 4th. You're giving yourself better take off torque (especially first gear), but not helping anything really on the highway.
Just my pair of pennies.....
