2016 Ram 6.4 Problems: sunroof leak, trans seal
Aggiect01
Cypress, TX
hemi 6.4
I have been happy overall with my 2016 Ram 2500 4x4, megacab 6.4 but I just wanted to make a few issues that I've had know to others so that they can be on the lookout.
1: Sunroof leak- I noticed water in my center console and ended up having my sunroof replaced under warranty
2: Transmission seal leak: I was under my truck greasing the front u-joint and noticed a few drips of transmission fluid on the bell housing. I took it into the dealership and they dropped the trans and replaced the transmission pump seal and fluid. I only have 16,000 miles and never offroad.
Keep an eye out and check under your truck periodically. They may just be isolated problems but better safe than out of warranty!
crazy jerry
WY
had a terrible rain one day and the sunroof leaked on mine. wiped off the rubber seal incase some dirt was jammed in there. far as i can tell it only leaked the one time
TonyMM
2016 RAM 1500 CC 6"4 4X4
What was the production date of your ram with sunroof leaking?
Iron Outlaw
My radio started powering off and on randomly. I also have a slow antifreeze leak. No other Leaks yet. 19000 miles of lots of towing and hauling.
zonacats
The radio in my 2016 also powered on and off randomly, twice, while driving yesterday. First time its ever done it. 14k miles
zonacats
Do i have to take it to the dealer to update that? Mine hasnt been to the dealer since i drove it off the lot.
2015HD
Maine
Shouldn't, problem and solution were both pushed over the air via Sat radio on Monday.
wallacemf
2500 4x4 Hemi 6.4
I have a 2016 2500 with Uconnect 5, mine started randomly rebooting yesterday. Turned out to be I had updated the iOS on my iPhone 6s to the latest version. Once I deleted the phone and paired it again, it was fine.
Hemi395
Cape Cod MA
Mines not a 2500 but I have the 65RFE and I had the exact same trans leak around the same mileage. Mine was the pump seal as well. Seems to be a somewhat common thing with the RFE trans.
Iron Outlaw
Thanks for the radio posts and sorry for hijacking. Nice to know I don't have something else to fix.
Hemi395
Cape Cod MA
Should say on the sticker on the door jam that tells tire pressure
