2017 3.6 pentastar temps?
Yellow dog 55
New Jersey
3.6 Pentastar
681B22DA-BE71-4387-9D0E-F78AC37D0392.jpeg does this seem right? Seems a little high for highway cruising in 70 degree weather.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
Yep, the temps in my 13 ram did the same, 8spd trans. typically runs hot too
M² Mods.
Don't worry about the transmission temp unless it starts to exceed the coolant temperature.
Yellow dog 55
Yellow dog 55
New Jersey
3.6 Pentastar
I did and oil change on it for the first time last week. The oil looked like **** that came out of it. I switched to mobile one and used a mopar filter this time. And what a stupid placement for the oil filter.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
My 2015 Pentstar runs around the same temps ! I was concerned when I first got my RAM but like you found out they do run hot ! Still bugs me lol
huntergreen
Marine Corps Navy Badge
What oil did you use ? And how long did you run it ?
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
On my motorcycles I had conventional oil at first and like you the oil looked like **** after a oil change.. When to 100% synthetic and first oil change was not as bad as conventional then each change looked better. almost to the point on saying why change now lol.. Even with 100% synesthetic I still change truck and bikes at 5k. You will see the difference next change. Synthetic has better thermal break down and carbons less..
YMMV
Yellow dog 55
Yellow dog 55
New Jersey
3.6 Pentastar
I’ll check later. All oil changes were done at dealership prior to this one. I changed it this time 100 miles before the sticker the dealership put in the windshield. Oil change meter was still at 29% when I changed it yesterday.
PoMansRam
East Aurora NY
My 2017 Ram 3.6L is the same. I've driven in 92F+ degree days and had coolant temps well into the 220s and trans temps around 210-212.
I've read that the danger zone for trans temp for the 8spd is 240+
In regards to engine oil, when I did my first oil change I had about 7500mi on the dealer installed (unknown) oil. What drained didn't look bad at all. This was with a made in China oil filter element. My truck was bought used with 12K miles on it.
I put in Napa full synthetic 5w20 and a Napa gold filter.
