2017 5.7 VERY Rough Idle…But only for a minute
mwaters97
Maryland
Kind of a weird one here. I did search around on the forum to make sure I wasn’t double posting, but couldn’t find anything quite like what I experienced today.
A little background:
2017 Ram 1500 Sport 5.7 Hemi
~85,000 well maintained miles
Have always run the “recommended” 5w-20 changed at 7k intervals
Bone stock (only things that may be slightly different with the “sport” than other trim packages is a mopar CAI and “performance” exhaust, but again both are original to truck)
The only existing issue that I am aware of on the truck is the leaking exhaust manifold. Believe mine is only on the passenger side for now. I have had the ever so common “cold tick” for about 20k miles now (of course it started just outside of warranty) and as this truck is the 2nd 4th gen 1500 I’ve owned with the same issue, I’ve just chosen to ignore it.
ANYWAYS
I’m hoping someone could provide some insight as to how to go about diagnosing the issue I experienced today.
I can only describe it as an EXTREMELY rough idle. I had been driving for over an hour already, so it was all the way warmed up. Put in in park to get out and get the mail upon getting home. As I was sorting through junk mail at the end of the drive, the truck began to idle very rough. Far more than a miss. RPMs would dip to nearly a stall, and fire back up to over 2 grand every 10 seconds or so. Also sounded like some knocking and other awfulness. Feathered the accelerator to no effect, like it wasn’t even there. It sounded and acted bad enough that I was truly worried I would be pushing it the rest of the way down the driveway. No trouble lights on the dash at all. Shut it off, checked the basics (motor still contained oil, nothing is on fire). Went to start again, same rough idle and no throttle response. Waited about 30 seconds, started again….no issue.
Curiously, instead of heading down to the house like I probably should have, I backed out of the drive and drove about another 5 miles to see if the issue reoccurred. Multiple times stopping, parking, idling, and even cycling the ignition. Could not recreate the issue.
Drove back home and hooked up the code reader, I use v-linker with an app that displays all ELM327 data. No DTCs whatsoever, like the truck never even knew anything was wrong.
Just curious if anyone here has experienced anything similar and if so had any luck diagnosing.
Thanks in advance!
Burla
2010 Hemi Reg Cab 4x4
Last time this well maintained ram had it's throttle body cleaned?
It isnt the exhaust leak, how sure of you that the tick isnt lifter tick though?
jws123
nj
If you can try to upload a vid of it running.
M
mwaters97
Maryland
Odd behavior can often be attributed to a bad or weak battery.
Any chance your still running the original?
Yeah, still the original. Reads 12.2v on the multimeter though and the truck hasn’t seemed hesitant to crank or anything recently. Worth replacing anyways just due to age you think?
M
mwaters97
Maryland
Ooo you definitely caught me there. That is one thing I have not done. Certainly couldn’t hurt to clean, I’ll do that with the upcoming oil change. Just curious/doubtful if that would cause such a significant “hiccup” so suddenly and then vanish the same way.
Fairly certain the lifters sound okay. Confirmed the tick is exhaust. I even know which bolts are snapped….well at least I did a few months ago, more have probably bit the dust since then.
Burla
Very few people actually clean their throttle body, but it is a 20k service in most cases and you can opt for many levels of clean, you can just pop the air and spray some carb cleaner on it and get what you can and see how bad it is. It would be a very likely suspect in rough idle at that mileage. Gas, air, and spark, now most of the time I would think if you get rough idle with no CEL, check air first of which of course TB is part of the air system. Now, even though you have 100k plugs, most guys are in the camp those should be changed before 100k miles, which would mean those are due at some point soon, but my guess would be spark isnt the issue.
Burla
throttle body cleaner
Interesting first sentence? A throttle body needs cleaning when the engine idle is rough...
JHoward
NW, Louisiana
5.7 Liter
Fwiw, I've read here in the RAMforum that sometimes rough engine idle could also be from the upper intake manifold bolts being loose and that periodically retorqueing them could solve the rough idle issue.
On my HEMI engine a few were loose but there wasn't any rough idle, either. I'll include checking them @ every oci anyway ...
I'm not savvy at cut/cop/paste, etc. so I took a screenshot of the post and placed it here.
grizzstang
Calgary, Alberta Canada
A fully charged 12V vehicle battery should read 12.6 volts or higher. IMO your battery is on the way out.
I agree that your throttle body should be cleaned and intake retorqued (I have retorqued mine a couple of times) but I am leaning toward a battery issue seeing what yours is reading.
Both the throttle body and intake have specific procedures that should be followed. Threads on those can be found by searching the forum.
