2017 8 speed Transmission
Troy Gillis
Alberta, Canada
Or.. drive it till it packs it in.. Car-Part list's these tranny's around a thousand bucks with only 1500 miles on it..
Burla
2010 Hemi Reg Cab 4x4
Learn how to service your transmision and deal with it with a smile on like Sean did, one great transmision, Defintly a upgrade over the rfe, except in maintenance. I would even think higher of it if they didnt mechanically heat the fluids. Delete that, just maybe the lifetime fluid makes more sense.
tidefan1967
Summerville, South Carolina
I agree unless you are physically unable due to advanced age or a handicap there are more than enough videos out there to show anyone how to do it. No way in hell I would trust someone else to not screw up and no way in hell would I pay someone a small fortune to do something that I can do myself. If you got $800-1200 to give somebody for a couple hours work at the most you must be made out of money. I wonder whats the most mileage someone has got out of one these without a transmission service before it actually crapped out? Probably longer than we would think.
Think i'd rather stay on top of servicing the tranny.Servicing one isn't cheap,and has a few steps to it,but it's a hell'va lot cheaper and easier then changing the transmission.Even taking your time the service is maybe a couple hours,swapping the tranny is going to take more then that,and you'll have to hunt up a tranny jack etc.and you'll have to either tow it to a dealer or find somebody who can program the tranny to the truck,you can't just throw another 8 speed tranny in place and drive it away,it'll need to be programed to the truck before you drive it .Plus if you buy a used one,you should probably do a service on it
madtrucker2016
New York-Staten Island
3.0 Hurricane twin Turbo
Very few dealers are familiar with servicing the 8 speeds.Pick a facebook page like Tuned Rams or High Preformance Rams,and i'll post the instructions that came with my tranny,and they are very specific about getting it level.The only part of the instructions that are high lighted and capitalized is the part about leveling the tranny rail,so apparently ZF and FCA figure it's pretty important to level the tranny pan rail,lol
well if you say that your ram came with instructions how to fill the transmission I must of missed that in my paper work with my truck when I got it new. But if you fill it level like you say then put back on ground wouldn't it be filled to much. From some videos Ive seen one was from a Ram dealership it was filled on a lift and also if you have a heavy duty cooling system for the trans it takes more fluid because the lines go up to the front of the truck into the cooler and back . They filled it till fluid came out of fill hole capped it drove the truck and put back on lift and filled it again till it poured out the fill hole and that was it
madtrucker2016
The way I always looked at tackling a job is watch listen learn then do so how hard could it be to change your own trans fluid they have kids in the dealer working on these trucks half my age so why cant I do it worked with my hands all my life
You missed the point where I said,"the instructions that came with my brand new 8HP70",the instructions came with the transmission not the truck.If you want i'll post the instructions on the facebook page of your choosing,i don't do pics on here,and you can argue with the instructions all you want there.I'm not gonna argue with you,i'm just telling you what FCA and ZF specify in the instructions that come with a brand new transmission,"not a rebuilt". Same as checking your engine oil,do you pull the dipstick when the truck is on an incline or leaned over in a ditch "no" as you'll get a false oil level reading,what makes you think the transmissions oil level is any different.All i'm saying is they are very specific about having the tranny pan rail level to do the checking procedure,and to me it makes sense,not sure why it doesn't to you,but maybe you are the type who pulls the engine dipstick while the truck is inclined,lol.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Well I was close on the name in another post.....instead of WildAss its Wildman.......LoL
Damn last name nearly killed me in my younger days trying to live up to it,lol.Had an old judge after i'd been up before him 3 times in less 2 months for scrapping and just generally being a ********,tell me I didn't have to try to live up to it,then he threw my ass in crowbar hotel for 90 days,just so i'd remember his advice,lol.
16RamHemi
Western Maine
Hemi 5.7 Sport Crew
what is a proper way to "flush" all the fluid out? i am strongly considering going to redline d6 but dont want to have a mix in there. will just draining until it stops be sufficient?
You can dis-connect the cooler lines up by the pass of the rad and flush out the cooler.I used my syphon wash gun and a rag wrapped around it ,to keep the majority of air and fluid going through the cooler with my compressor regulated down to 35 psi,i did that on both lines to flush as much of the old fluid out.That and a pan drop will probably get 70% of the old fluid out,but the convertor + heater assembly and cooler lines are still going to be full of the old fluid.I was under the impression D6 is supposed to be compatiable with the ZF 8/9 speed fluid ,if it's not,and you need to get all the old fluid out,it'd be cheaper to just use the ZF fluid.
16RamHemi
Western Maine
Hemi 5.7 Sport Crew
unfortunately all that stuff is over my head. not too mechanically inclined. ill probably do a change out, then do another a short time later. ill buy the pan with serviceable filter. yes i believe Redline d6 is compatable. i was thinking that when a fluid was compatable / ok for 8hp70, it meant good for the trans. not necessarily ok to mix. thats even better if thats the case. depending on how the fluid looks will give me an idea how long before second drain and fill. does anyone do trans fluid analysis? if so would it be useful to show wear to give an idea of any issues?
Mr led
Mississippi
3.6 v6
Hello Everyone!! (Newbie here)
Just hit 100k on my '17 1500.
Yes I drive a lot for work....
I have asked multiple dealers regarding if the Trans fluid should be changed?
Responses: 1) It's sealed for life don't touch it. 2) Don't change it till 120k.
3) You can but you must use Mopar fluid only, no one else makes it and it's $40/qt.
Curious if anyone has changed the fluid?
Appreciate any help!!
Mr led
Mississippi
3.6 v6
Here is a place that make a better fluid. For dodge transmission. Call brain tell him bill told yo to call. #440-821-9040 in Mississippi. Oil is called quantum blue . I think is 14.50 a qty. Meet all specks. Have a good day
mopareg
Missouri
6.4L HEMI
why can't you just put a funnel in the trans dipstick and fill it that way?
First off you'd have to build the dipstick,lol.The 8 speeds don't have a traditional dipstick,they have a fill hole on the pass side of the transmission,that you fill and check the fluid with.
