Jim Guyton
Hello,
I was hoping for some help with the gear swap on my truck. I picked up a 17 Ram 1500 3.6 with the 8 speed trans and was told it would pull 7000 plus pounds (Only reason I was ok with the 3.6 v6) but I sold my RV and was going to buy a tow camper and now I'm finding out that I have the 3.21 gears and it will only handle 4200lbs. I did find that I could of got the same truck with the same drive train and 3.55 gears to get with the 3.6 to be able to pull 7000 plus lbs. I have sourced a full rear setup and front center section from the same year with 3.55 gears. The questions I have are:
1. Do I need new front axles also or just the center section?
2. If I do the swap will the computer pick up on the swap or will my speedo be off and or will I have a check engine light that I will have to deal with?
3. Will I have to have it reprogrammed by the dealership?
4. And will just a gear swap pick up 3000lbs. extra towing lbs.?
