2018 Ram 2500 gps issues
johnddavisjr
California
Cummins
Curious if anyone has tried an auxiliary antenna or the global positioning sensor replacement(just stumbled across this sensor and starting to research)
I have been trying to avoid a radio replacement or aftermarket radio
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
I've used a $10 antenna from Amazon that works but you loose SXM.
J
johnddavisjr
California
Cummins
i saw a dual antenna spliter from infotainment that may then allow for both.
Did you SXM work and you not have gps signal?
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
I don't recommend Infotainment. You can also get the splitter on Amazon. Give me a second and I'll post links. I know it does work, but my SXM reception has always been sketchy so I'm not sure if it works "well"...
