2018 Ram Rebel - OBD/Security Bypass not working
kcampbell09
I recently purchased a new key for my truck and wanted to program it... so i purchased a bluetooth OBDII reader, the cable to bypass the security module, and alphaOBD.
Everythiung connects correctly but everytime i go to read the pin or "program Ingintion FOBIKs highline System" i get an error "failed: Invalid security key." I cant see anything else i need to do to bypass the security module to let me program the key. please help!
On a side note when i connect directly to the trucks OBDII port without bypass i can get to the pin but i get a timeout error, however, if i span start enough it shows the PIN# randomly so i have the correct #.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Have you been able to program any changes in the BCM at all using the SGM Bypass and OBDII adapter you are currently using?
K
kcampbell09
@SitKneelBend I have been able to update the DRL, but nothing within the Radio Frequency hub (RFH). I just thought that i completely removed the radio from the center console so I can reach the security module. Maybe the radio needs to be installed for some reason. I'll try that to see if anything changes. its annoying to take apart the console to try every time.
UPDATE: tried reading the pin and programing the key with the radio still connected and still receiving a failed security error.
@alpinegreenneon I am using one suggested to me by a mechanic friend: https://www.amazon.com/dp/B00PJPHEBO?ref=ppx_yo2ov_dt_b_product_details&th=1 . Its on the cheaper end so it may not have the ability. it was able to make some changes to the Car config under the body computers.
SitKneelBend
Moderator
St. Louis
3.6 Pentastar
It "may" be the adapter you are using. I used one like that on my 2014 to change mileage without issues though. The recommended adapter (from the developer) is the OBDlink MX+. It's a lot of money to spend though if that is not the problem, but the MX+ can intelligently switch its configuration to communicate with different modules without the use of further adapters for specific configurations.
RamDiver
Marlborough, Ontario Canada
2021 DS
I use the OBDLink SX and physically connect it to a Windows laptop.
It costs much less than the Mx+ and likely far safer and more reliable.
The idea of using any Android OS device for AlfaOBD and then a wireless Bluetooth connection just does not compute in my head.
You want to make critical adjustments to the brain of your truck without screwing things up, why would you choose a POS OS and a wireless connection?
OBDLink SX Amazon.com
04fxdwgi
Coastal NE North Carolina
2016 1500 Sport
I don't believe the budget OBD adapters use the correct bi-directional multi protocol communications formats, if they are even proper bi-directional..
They can usually read fine, but writing is a whole other ball game.
DoughRat19
Massachusetts
2019 Classic
If you are on the current version of Alfaobd, there is a bug. Assuming you’re using an android device, uninstall it and use this link to install an older version that should work: https://drive.google.com/file/d/1nz53G-8oeZ7wXsycwyNygx89Y5zy24D5/view?usp=drivesdk
As far as being able to pull the pin, it’s not giving you the correct pin without a bypass cable installed. You’re probably getting something like 0041, 0043, 0047, etc which is not your actual PIN number. So if that is the number you are using, pull your pin again with the older version of Alfaobd (with the bypass installed) and then try to program a fob again.
04fxdwgi
2016 1500 Sport
Latest windows version is v2.5.2.0 (March 31st this year). Is the "bug" related to the pin pull sequence??
Newest Androind version is 2.3.8.0 on March 5th, 24.
K
kcampbell09
I went ahead and went to an auto shop and they programmed it. However I just noticed my original key isn't working now.... ffs. Hoping it's a bad battery.
Steve Holtz
