2019 HD Tail lights in a 4th gen
them0difier
Houston
Quick question, I see that the 2019 terminal uses two grounds. Pin #5 and #8. I’m just doing the basic setup. Does the adapter harness need to connect to both grounds or just one of them?
Thanks
Roman217
Metro Detroit, MI
Thanks
On the right side, use all 3 grounds. On the left side, skip the ground on pin 8.
Roman217
Metro Detroit, MI
Okay, so why skip pin 8 on left side?
The blind spot sensors use the ground on pin 8 to define sides. So when pin 8 is grounded it defines the sensor as the right side, ungrounded defines as the sensor as left.
S
superjoe83
Oregon City, OR
Which mirror glass were you using when you ran into this problem? Were they the 2019 glass with the LED Blind spot light?
No, I haven't got the 2019 glass yet, it should be here next week, I am using some generic indicator LED's that I put behind the mirror glass and can see the reflection on the chrome mirror housings, I'll post a pic, I had everything enabled, but because I didn't have the indicators hooked up to the door modules, it would not let the system operate because of the active trouble codes in the door modules. After I installed the LED indicators everything worked correctly. I will update once I get the 2019 glass, it should be getting here Wednesday or Thursday
them0difier
Houston
Okay, so why all 3 pins on right, and not just two?
them0difier
Houston
1st ground is for the tail lights, 2nd is for blind side sensor side definition, 3rd ground is for the blind spot sensor.
But I’m just doing a basic setup(no blind side/spot).
So do I only use #5 pin?
Jimmy07
But why all 3 on right?
Another way to explain- both sensors sitting on the bench are identical with the same circuits to run them with two grounds. If both grounds are hooked up on both sensors, the can bus thinks there are two right side sensors. By NOT grounding pin 8 on the left side, the can bus can now differentiate between which one is the left side and which one is the right side.
them0difier
Houston
If you’re not running the blind spot, you only need to use pin 5 as the ground for the lights.
Thanks for the confirmation. Hopefully this will help others reading this thread, and just doing a basic setup.
Jimmy07
Just did a bunch of testing. Five layers of masking tape on the sensors, and they still pick up cars at the same distance. That’s enough for me to be confident I can paint the sensor part max steel metallic.
Roman217
Metro Detroit, MI
Paint the masking tape with the metallic paint before committing. The metallic paint may mess with the sensors.
The Grand Cherokees have been know to be sensitive to paint resprays on the bumpers.
bellaireroad
Fort Worth
Thanks, Keeping fingers crossed you get the glass to fit[emoji1695]
Jimmy07
Got some leftover color match from when I did headlight housings going on the tape right now.
chrisbh17
A general question about these taillights...how do they work *as lights*? Are they actually bright LEDs?
I replaced my stock with factory LED tails but had to replace the backup lamp on the factory LEDs since they still used halogen. The replacement LEDs are brighter than all get out....how is the brightness on the HD taillight backup lamps?
Roman217
Metro Detroit, MI
Go big and just get some super metallic rattle can from an auto parts store to make it a worse case scenario. Throw two layers on and see how it does.
Roman217
Metro Detroit, MI
A general question about these tiallights...how do they work *as lights*? Are they actually bright LEDs?
They are pretty bright. They are at least on par with my LED tails. The reverse lights are brighter by a huge margin.
ChloeBrooks
