Did it occur to you to A) read the owners manual as every Chrysler/Ram product I own has a selectable feature for that on the settings - locks page. I however don't have a 2025, B) go see the dealer you bought it from?
AUTOMATIC DOOR LOCKS — IF EQUIPPED
The auto door lock feature default condition is enabled.
When enabled, the door locks will lock automatically
when the vehicle speed exceeds 15 mph (24 km/h).
The auto door lock feature is enabled/disabled in the
Uconnect Settings ð page 203
Doors & Locks
When the Doors & Locks button is pressed on the touchscreen, the system displays the options related to locking and unlocking the vehicle’s doors.
NOTE:
Depending on the vehicle’s options, feature settings may vary.
Setting Name Description
Auto Door Locks This setting will allow you to change if the doors lock automatically when the vehicle
reaches 15 mph (24 km/h).
Auto Unlock On Exit This setting will unlock the doors when any of the doors are opened from the inside.
Flash Lights With Lock This setting will allow you to turn the flashing of the lights when the Lock button is
pushed on the key fob on or off.
Sound Horn With Lock This setting will sound the horn when the Lock button is pushed on the key fob. The
“Off” setting will not sound the horn when the Lock button is pushed. The “1st Press”
setting will sound the horn when the Lock button is pushed once. The “2nd Press”
setting will sound the horn when the Lock button is pushed twice.
Sound Horn With Remote Start This setting will sound the horn when the remote start is activated from the key fob.
Remote Door Unlock, Door Lock/1st Press Of Key Fob Unlocks This setting will change how many pushes of the Unlock button on the key fob are
needed to unlock all the doors. The “Driver Door” setting will only unlock the driver
door on the first push on the Unlock button. The “All Doors” setting will unlock all
doors with only one push of the Unlock button.
Digital Keys This setting will open the Digital Keys main screen, if equipped.
Passive Entry This setting will allow you to turn the Passive Entry feature (Keyless Enter ‘n Go™) on
or off.
216 MULTIMEDIA
Personal Settings Linked To Key Fob This setting will recall preset radio stations and driver seat position that have been
linked to the key fob.
Power Tailgate This setting will allow you to change the settings for the power tailgate. The selectable
settings are “Manual” and “Pow
2025 RAM 1500 âžœ Owner's Manual âžœ 100% free PDF ✅ The 2025 RAM 1500 is a full-size pickup truck designed to deliver robust performance,... â
www.rammanuals.com
