Jeepwalker
- Sep 8, 2017
- 3,240
- 3,468
- Location
- WI
- 2012 Reg Cab, 4x4
- 5.7 Hemi
Definitely suggest the Toyota route. Theirs is probably only 4 easy payments of $549.99.
you literally have to drop the transmission to change the fluid, and you think ram zf is bad, lol? If you get the 5 liter that is the process, I believe the 3.5 liter you don't have to, but that isnt any easy change either. The only real issue with the ram 8 speed is the process to check the fluid, that is what blows, but it is an easier dyi process then the 10 speeds. Now if you go to the dealer, well whatever expect to be out $$, My local toyota dealer wanted over 2 grand for 4 shocks and only two of them were struts, the other two just regular shocks. Me and my brother in law did a 4 strut change in 7 hours, it was no joke removing seats, dropping the knuckle, removing calipers, etc, but the cost was under 400 for parts. The only way forward in America for normal folk is find a way to do this sh i t yourself no matter what you buy. But, if you want to do yourself a favor, buy stuff from the 60's, 70's or 80's as opposed to these ridiculously complicated machines. All of this garbage is by design, they don't want the public to dyi, to be able to do your own stuff, to be the capable people you were meant to be.
Dang Camry 4 corner strut package, what a waste and a nightmare. Why do manu's just not use shocks? sigh
Stills sounds like a PITA though. I guess I’ll find out in a few years because with these prices and interest rates I’m not going to be changing trucks again anytime soon.You don’t have to drop the transmission on the 5.0. You have to remove the sway bar, cooler lines, and then jack the rear of the transmission up off the Cross member.
3.5 and 2.7 you don’t have to Jack up the rear of the transmission.
As I like to say to these "I am taking my ball and going elsewhere" posts, Don't let the door hit ya where the good Lord split ya.Absolutely insane. $600 just for the fluid. See ya boys. I’m out of the Ram game. Trading in. Going back Chevy More than likely.
Black trucks matterDefund the Ram Dealer.
I had a conversation with the service writer at my local RAM dealer the other day, about the recall on the HD trucks and the trans dipstick replacement. .......According to him, they are a throw away, non serviceable unit.
I had solenoid pack go out on my 08 1500. Tech told me there is another filter under the pack that never gets changed since most corner lube joints will pull the pan and change the one filter only.The filter is built into the pan. Crazy
Depends on the vehicle. Dodge transmission now do not have a fill tube or pan on the botttom. They are hard to service outside of the delaership and expensive to repair. The days of 6 qts of dextron 4 are over. They are extremely expensive to repair or replace too. Will not matter if it is Ram or the new GM 10 speed.Absolutely insane. $600 just for the fluid. See ya boys. I’m out of the Ram game. Trading in. Going back Chevy More than likely.
good by, close the door on your way out.Absolutely insane. $600 just for the fluid. See ya boys. I’m out of the Ram game. Trading in. Going back Chevy More than likely.
I watched my son's neighbor over the course of two days change his F-150 10-speed transmission filter and fluid. Had to disconnect a whole bunch of things to facilitate removing the pan, including dropping the sway bar. I'm pretty sure the ZF 8-speeds have a drain plug in the oil pan. The Ford's, apparently, do not. This makes for a very messy fluid dump of the pan even though he raised the back of the transmission. He also had to replace broken studs that held the heat shields on, and replacing the pan gasket was hindered by the lack of room over the top of the exhaust.you literally have to drop the transmission to change the fluid, and you think ram zf is bad, lol? If you get the 5 liter that is the process, I believe the 3.5 liter you don't have to, but that isnt any easy change either. The only real issue with the ram 8 speed is the process to check the fluid, that is what blows, but it is an easier dyi process then the 10 speeds. Now if you go to the dealer, well whatever expect to be out $$, My local toyota dealer wanted over 2 grand for 4 shocks and only two of them were struts, the other two just regular shocks. Me and my brother in law did a 4 strut change in 7 hours, it was no joke removing seats, dropping the knuckle, removing calipers, etc, but the cost was under 400 for parts. The only way forward in America for normal folk is find a way to do this sh i t yourself no matter what you buy. But, if you want to do yourself a favor, buy stuff from the 60's, 70's or 80's as opposed to these ridiculously complicated machines. All of this garbage is by design, they don't want the public to dyi, to be able to do your own stuff, to be the capable people you were meant to be.
....He was quoted $2700 by the dealer for this job and I think he now believes it's worth it.
