2500 softer shocks?
Dmopar74
Are there any softer shocks for our hd trucks? My truck rides like a brick compared to my brothers gmc hd.
mtnrider
Georgia
Shocks only control dampening and rebound of the springs so swapping them won't do much for what you are looking for unless yours are completely worn out. You have a HD truck with HD springs and it is going to ride rough. There are softer aftermarket lifted springs available but you are going to lose load capacity and it's not cheap.
Maybe try throwing some weight in the bed, that might help.
mtofell
If you really want the best of both worlds (soft ride and load capacity) look into a Kelderman replacement air suspension kit. And, unless your brother's truck has some modification it rides the same or worse than your truck. I found the Ram 2500 to have the best ride of the big 3 due to coil springs vs. leaf springs. As mtnrider said, it's an HD truck. You just can't have a soft ride and HD capacity. The laws of physics say so.
Firebird
2019 Ram 2500
What size rims do you have? I found that the 17 and 18 inch wheels with taller sidewall tires ride much better than the 20's and short sidewall tires.
BlkZrx
northeast IN
2016 2500 SLT Std. cab
Tire pressure makes a big difference too..
Sent from my LG-K540 using Tapatalk
Fitz-0518
Veteran 66-68
Central California
2018 2500. 2018 1500
Have the same around town, ****** streets bumpy ride in our 2018 2500 CC. I knew that when we went from the 07 1500 Mega Cab to the 2500, we would notice the ride trade off. We have 17x8 wheels withe Firestone high wall tires. I run the pressure at 50 front and 60 when "not towing" It helps. When I get to about 10-15,000 miles I will replace the shocks with Bilstein. Will replace the tires when needed with Goodrich or Michelin. Firestone rubber is hard, but they get the miles. As said,,,it is a HD truck.
2016Bighorny
Wisconsin
Well...GM has IFS and Ram has a solid front axle!... there is NO comparison between the two for ride IMHO...
D
Dmopar74
This is what I'm thinking also, I do have some rancho 9000 shocks i used when I hady camper, might put those back on
