2500 Towing
Ramit2500
Can anyone recommend a good 2.5 x 2.5 adjustable hitch ball with 6000lb capacity or more? 8'' drop or more would be great. Just not finding much with good reviews. Thanks for the help!
Ionicbrick
I've been towing work trailers, camp trailers and ATV trailers for ten years. The weigh safe hitch above is definitely the best hitch I've had and the scale is fairly accurate. One thing to note, if you load the trailer to light on the tongue the hitch rattles quite a bit. Load it right and it's a dream. I've towed around 9500lbs with mine with no issues. Highly recommended.
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Welcome to RF.
loveracing1988
Clarkston, MI
freedhardwoods
Cummins 6.7
JeepN77
Maine
Cummins 6.7
I remember shopping for a drop hitch. You don't really realize how tall the hitches are until your trailer is at an angle.
I have a B&W Model 10. I love the hitch, but it's only 2" not 2.5". I use it for everything so I can swap it. I just use the reducer that came in the truck. I do take it out when I'm not towing. It clangs around back there to much for my liking. Hoenstly I wish I bought a Model 12 instead. If I put bigger tires on it I would probably need it.
Hope this helps. Good luck!
EvanYJ350
2016 2500 CC Air Susp
6.4L 392 c.i.
Another vote for the Weigh-Safe. Great product.....
opie
I also purchased the Weigh Safe, 8" drop class V.
It works as advertised. Would be nice to have it fit a little tighter in the hitch considering its all machined.
BossHogg
Navy Badge Law Enforcement
Oakland Township, Michigan
6.7L Cummins
Add me to the weight safe users' list. Class V 10 inch drop. Expensive yes, but you only have to buy it once.
Just an FYI, Weight-Safe told me they are coming out with dust caps for the pin lock and scale face. Should be available by spring.
