BigMike71
I just had Toyo Proxes St 3 put on my stock 20x9 chrome clad wheels on a '15 2wd crew cab. The 305/50 20 will rub the sway bar and there is maybe an 1/8th inch clearance with the upper control arm. I'm trying to decide whether to stay with this size or switch to a 275/55 20 at least in the front since they are about an inch narrower. Also I am entertaining the idea of a 1 or 2 inch drop in the front, if I do this would the rubbing problem get worse?
Give your thoughts.
Give your thoughts.
