360 Revs high at start up
Powerddge1138
I replaced the intake manifold gasket and it started and drove great but it idled high, so I adjusted the idle and it was PERFECT. Then one day I started it and it reved up like crazy, I dont have a tach so I dont know how high, but it was nuts. I try starting it and tapping the pedal but it doesnt help. Its throttle body.
P
Powerddge1138
Yeah I adjusted the idle like i said and it was running smoothly
crazzywolfie
under the truck
if you did not adjust it properly like the procedure i posted above then you most likely threw it off. the TBI system can be a bit picky.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
I love stuff like this we have a 199X Ramcharger on the farm as a plow truck and it needs some work like this maybe. Ours has issues starting but I can't figure out why I have pretty much given up on it. Would this adjustment cause issues on startup or is that something else altogether. I know it is fuel injected but this thing is in very rough shape maybe I could get a video.
$miley
P
Powerddge1138
Its funny cause in the morning when it is cold it acts like it has a huge cam in it and lobes sometimes, but after you drive it for a while and it warms up it goes away, could the actuator being adjusted wrong cause that?
crazzywolfie
under the truck
it is possible. really the only way to find out is to try. these older trucks can be picky
crazzywolfie
under the truck
i hang out on some forums that have stuff like that posted and gather what i need from there.
Reticle918
