360 won't stay running
Lincolnator
Waco Texas
So I have installed a rebuilt 1986 360 engine in my 1988 Ramcharger. New edelbrock intake, carb, all new fuel lines, fuel pump and sending unit. Truck starts up and runs great for about 3-5 minutes and shuts down. I am thinking an electrical problem. I have made it egr delete and removed all emissions pump, sensors etc. Can some omne give me an idea of what I am missing?
diymirage
Banned
Sounds like you might be out running your fuel
Do the bowls have sight glasses ?
The ballast can be bypassed to run a solid 12volt for diagnostic purposes
After the truck dies, what happens, hit the key and it fires right back up or does it it need to catch its breath ?
David Vandercook
Under the truck
Yeah, does it restart after it dies? If not test spark once it dies, if you got spark dump gas in the intake, see if it runs a couple seconds then. Should get you started.
metalchewy
Las Vegas
2010 TRX4
4.7L
Old coils can separate internally after heating up. Work fine up until that point.
If you have a spare, swap it in and see if it helps.
JC Mellado
Mexico
I´m having the same problem as described intially by Lincolnator. I´ve done suggestions described above. Any additional suggestions? I´ve also changed rotor, sparkplugs, spark plugs cables, distributor cover. Any help sincerly appreciated.
metalchewy
Las Vegas
2010 TRX4
4.7L
Do you still have spark after it dies?
JC Mellado
Mexico
Yes, it starts again but then revs go low and then just dies.
