3rd brake light?
hemisport5.7
Canada
I’m thinking of upgrading my 3rd brake light bulbs to LED. If I remove the assembly will I have to use a sealant so it doesn’t leak? Also I’m wondering what bulbs you guys are using so I don’t throw a “bulb out” light.
Purplert
I’m running bulbs from diode dynamics, no it’s a gasket on the light that will come off attached to the light... no need for a sealant.
Ramm5.7
So Cal
2019 Ram 1500 Classic Bighorn
Hemisport, since you live in canada try The Auto LED. They are there also. Facebook or interweb
jasonw
South Dakota
3.0L Hurricane HO
If the seal is in good shape, no need for a sealant. Some earlier revisions of the 3rd brake light had weak/smaller seals that were prone to leaking. If you are reusing the factory brake light housing, and you take it off and discover you have a questionable seal, you have a few options...
1. Buy the newer revision brake light with thicker seal. I believe the latest revision is 55372082AF (replaced 55372082AA, 55372082AB, 55372082AC, 55372082AD, 55372082AE). I got mine for less than $20.
2. Buy good weatherseal from a hardware store, clean off the old small seal, and use the good stuff instead. Again, relatively cheap.
3. Use a RTV type of sealant. This is, I believe, what FCA's TSB says for the dealerships to do with leaking 3rd brake lights. Again, relatively cheap.
4. Buy the OEM LED/Cargo Cam 3rd brake light used in some 2500s/3500s. Very expensive option, in the hundreds of dollars or more unless you catch it in a junk yard, and the cargo camera will not work without a lot extra wiring work.
5. Buy aftermarket 3rd brake light, and if it doesn't have a good seal, apply solution #2 or #3 to it.
I opted for #1 myself, but many others here have opted for the others, and all seem to work.
Speaking of bulbs, you may go through a few before finding a good set that don't set off your truck's "brake light out" warning. I'd take the advice of the guys above. I went the eBay and Amazon route, randomly trying ones with good ratings, and it took me a while to track some decent ones down.
Teknoracer
Headlightrevolution.com has the bulbs u need and will not give u any issues. Check out all their other awesome lighting for your truck as well!!!
