4.56 or 4.88 ? Which are better for 37s?
C
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
IMO 4.56's will be plenty if you're coming from 3.21's...it'll be 42% more rpms than what you're currently working with with the 3.21's. Assuming those tires are more like 36.5", you're probably right around 1400 rpms at 70mph in 8th gear. Change to 4.56's and you'll be at 2000 rpms. Going to 4.88's just gets you another 100 rpms.
Oooh ok ... from talking with people everywhere they say I should be fine with 4.56s ... any concerns I should have if I go with 4.88s ?
RAM_Designs
Rockwall, TX
6.4L Hemi
Just depends how fast you usually drive. I routinely drive 75-80mph, so when I went with 37's I stuck with 4.88's instead of everyone saying they would go 5.13's (my final gear is .625 vs your .66, so my rpms are a little lower than yours would be with the same diff gearing). I live in a low elevation with minimal hills, and I drive 70+ all the time. Someone who lives at 5000ft, drives hilly/mountainous terrain often, and never sees over 70mph would have different needs.
C
2018 2wd
But you also have the 6.4 ... So what do you suggest or recommend I go with .... I rarely will see any hills, it's mostly all flat highways and city streets ... and remember it's also only a 2wd ...
RedSRT4Me
Scottsdale, Az
2015 CC Sport
I've got 11k miles logged on my 4.56 swap.
You'll be plenty happy with this upgrade.
I used Alfaobd to change my axle ratio in the BCM. Truck behaves like stock. Very pleased with the mod and functionality
C
2018 2wd
Nice nice ... what's Alfaobd in the BCM ? lol ..
RedSRT4Me
Scottsdale, Az
2015 CC Sport
AlfaOBD is software that can activate dealer codes to make functions previously not available to you at the palm of your hands. Its available for windows and Android operating systems. No Apple support at this time.
BCM is Body Control Module which accepts the inputs from Alfa via the OBD2 port to accept those changes. :005:
RoadRamblerNJ
Mountain City, TN
392 Hemi
Cool ... I think 4.56s it will be ...
After seeing the kind of driving you're gonna do (and, NOT do), I change my mind.
You don't need 5.13s.
4.56s will do you just fine on flat, sea level, asphault streets.
Now, if you ever decide you want to run stoplight to stoplight.....hehehe.
C
2018 2wd
Well you guys I am really regearing my truck on March 6th ... I will be going with 4.88s from Revolution/Motive Gears and getting them regeared by Premier West Gears in Riverside California. Anyone with opinions or suggestions on Revolution/Motive gears? I was thinking about going with Yukon gears but Carlos suggested Revolution, any thoughts ?
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Motive gears are good, we've used them in race applications.
Curious how it turns out!
RobertusvT
cn
Let us know how it goes! Just put 35s on mine and am looking to regear myself!
RedSRT4Me
Scottsdale, Az
2015 CC Sport
As long as it's installed correctly any brand that's competent should be fine.
I used yukon myself based on my research at the time.
2010 Infantry Vet
Butler pennsylvania
4.88 if you have the 5 speed, 4.56 if you have the 8
5/6 speeds have SAME overdrive ratio as the 8-speed. So trying to maintain 70mph if you live in a hilly area on the interstate all depends on tire size.
Always refer to a gear ratio chart.
Biggest front diff gears made are 4:56 unfortunately. But if your 2 wheel drive, rear can have 4.88
RoadRamblerNJ
Mountain City, TN
392 Hemi
I believe my 2500 will allow 5.13's frt & bk. Been a while since I was getting info. Had to put that project on hold since not working for 2 yrs.
C
2018 2wd
Ooooh yeah ... less than a week away ! I can't wait to see how it runs ... I am going to try and get some video of the installation ....
C
2018 2wd
Just dropped my truck off to finally get regeared with Revolution 4.88s ....can't wait to get her back!
Arturo Rojas
