Man I'm not trying to bust your balls too hard here but.. if you type in BILSTEIN UCA in the search box at the top in this section (4th gen, lifted) it returns almost 500 results and probably a quarter of those results answer the question you asked.
You're fine with the stock arms. The Mevotech arms are stock replacement arms and don't have corrected geometry for the raised ride height so they don't really bring anything to the table, you might as well keep your stock arms since they work fine. Bilsteins are the same extended length that stock struts are so they never go out of the stock range of motion.
When you change the ride height the neutral position on the lower arm alignment cams will change and at the highest 2.8" setting you're about at the end of their adjustment range, that's why upper control arms are helpful but not absolutely necessary with a Bilstein lift. But this is something the Mevotechs don't address since they're just stock replacement arms.
There now another search result that answers this question for the nobody who'll ever search it.
