- Joined
- Jan 17, 2016
- Posts
- 23,737
- Reaction score
- 54,529
- Ram Year
- 14 Sport
- Engine
- 5.7
So the MDS uses a slide valve actuated where it must move quickly in order to activate. If you use 5-30 the oil is thicker and may not allow the valves to move fast enough for a smooth transition. Also the bearing clearances and drain backs are very tight on the new engines, thicker the oil actually reduces the lubrication on the bearing surfaces and slows flow. If you damage your engine and the manufacturer can prove u used the wrong oil, buh bye warranty. Use a high quality stay in grade synthetic and you will NOT have issues. The lifter/cam issues on SOME 5.7’s was related to faulty bearing in the cam rollers... do not listen to the dibblers on here saying run higher weight oils. It’s total BS.....
If FCA's own printed manual up till 2017 states "5W-30 is acceptable if 5W-20 isn't available",your warrenty is still going to be intact for your 2009 to 2017 ,(and i'd argue the point that it should still be acceptable after that,as the engines haven't changed since the introduction of VVT in the 09 5.7 trucks),whether you run 5W-20 or 5W-30 as long as they both meet Ma Mopars specs for oil.To bad some of you guys don't have the 700+ page printed owners manual,as it has some very good info in it,that might change your tune as far as oil weights go
