6.4 Hemi Break In
Jaxyaks
The monitor is just a computer program that averages speed, idling etc to determine when to change, I'm pretty sure there isn't an onboard anylizer
Donelam304
Madison, West by God Virginia
HEMI 6.4
I don't start mine up and let it warm up. I usually just get in and go. I will start it up and let it run till I hear the engine idle go down.
I know that on atv's and side by side's at the bike shop we have to change the oil in the stuff we pull out every day about every 2 to 3 months. Because with it being fuel injected it has automatic chokes and idle. It contaminates the oil with gas where it sits and idles a lot. And the gas breaks down the oil properties a whole lot faster.
NewBlackDak
Hemi 6.4L
Same here. Push the button, wait for the RPMs to stabilize, put it in drive, and drive her super easy until it's up to temp.
Donelam304
HEMI 6.4
Wow. It doesn't make any sense to me why our milage is so different. You are using 0W40 also correct. I have been using a Purolator filter that had a sizable larger capacity. This new filter is the stock size. And it's about half the size and the Purolator I've been running.
hemi1282
Arkansas
2016 Ram Tradesman
My last oil change i got a little over 9000 miles took in at 10% and im pretty rough on mine i haulass most time to work an back 90mile round trip, i just checked my last two oil changes an I've gottin atleast 9k, i also let mine warmup for bout 3 to 5 mins, Newblack thats odd u get around 5k maybe u should drive it like u stole it big guy
hemi1282
Arkansas
2016 Ram Tradesman
Newblack we both have megacabs shouldn't be much of difference,
ramforme
hemi
Interesting. How did you arrive at the larger filter? Is it "approved" as a replacement filter? Do you add extra oil on the oil change? What is part number? And finally, did your research show other brands same size but larger?
Donelam304
HEMI 6.4
It was listed in their parts catalog (advance auto parts) yes, it held about ½ - ¾ a quart more oil. I'm not sure on the part #. It's listed as Purolator extra guard or extended life filter. It's just bigger on the outside diameter and longer.
NewBlackDak
Hemi 6.4L
I wonder if my dealership is doing something stupid, and not using the right oil. I'll go in there and blow up if that is the case.
hemi1282
Arkansas
2016 Ram Tradesman
Look on ya receipt it shows what oil they use, there was one guy on here that had checked his and they had put 5w20 in his ****, dont remember who it was but id diffently check ya papper work
Donelam304
HEMI 6.4
I would too. I asked mine to show me what they use. And how much per quart and 5 qt jug. That's another reason why I change it myself. I can't see paying $90 when I can do it for $50. And it only takes 20 to do it.
NewBlackDak
Hemi 6.4L
i checked all the invoices, and they state 0w40. That doesn't really mean the monkey actually doing the work did the right thing. This dealership includes 3 yrs of oil/lube/rotation with every new vehicle, or I wouldn't be going in. I'll do the next one myself to see if there is any difference.
1500ram12
5.9L Cummins
Don't remember why off hand. I just remember reading a few have tried running a 5w and 10w and threw codes. There is a sensor somewhere that can read how the viscosity of the oil is.
Sent from my D6708 using Tapatalk
Donelam304
HEMI 6.4
Yep. It will throw a code. Lol. And it will put the truck in What's called limp mode. Lol. You can only go 35 mph and limited to like 50 miles or some crap too. These motors are definitely not anything like a SRT 6.4L HEMI. Lol.
Blazin383
Blazin383
Pacific Northwest
6.7 CTD
So aside from all the oil change discussion, what other break in procedures have you used? Limited RPMs, limited speed, no towing or full throttle for xx number of miles etc.?
Donelam304
HEMI 6.4
I just didn't tow for maybe the first 300 or 400 miles. And drove it like I still do. A car today isn't like it was 20 years ago. If something is going to go wrong, it will regardless. Like some have got theirs and had bad fan clutches. And had to have them replaced immediately. Some had the 3rd break light leak. Some had bed and cab miss alignment.
granite14
Portland, OR
2014 Ram 2500, 4x4, CC, SLT Big Horn
My oil change indicator says about 8000 miles for expected life, but I've been changing it ~5500.
Ftank
