6.4 Hemi - Larger Replacement Tank!!
Mountaineer83
Charleston, WV
I wanted this thread to get all of the attention it can so I apologize if you thought there was a tank available already. No ill intentions!
After speaking with Transferflow, they have made it obvious that they are paying attention to the HD gas truck market. Between our 6.4, the Ford 7.3 and 6.2 and the others out there, the need for larger fuel tanks is becoming a more pressing issue.
What he told me was to have as many people as possible to go to the Transferflow website, and click on the "Contact" menu. Then select "Suggest A Product" and enter in the information. The more people who do so will push this higher up the priority list.
They already make 45 gallon tanks for the Tundra and the F-150 gas engines, so it is a possibility. We just need to make them aware that we want it!!
Jughed
Eastern Shore
2018 Crew Long Bed
Right now I can barely afford to fill up the stock tank!!!
But a bigger tank for towing would be great. I get about 200 mile range with the TT in tow. Not leaving much room for error finding gas stations that I can fit into with a 35' trailer.
My 94 F150 had 2 30+/- gallon tanks... not sure why a truck the size of these Rams only has on small tank.
Bldrinker
I emailed the new product guy.
Hi Michael,
Thank you for contacting Transfer Flow! Yes, we hear often about many new gas trucks not having the desired fuel capacity. We do not have a project currently in the works for the 6.4 Ram. I have noted your request and contact information. If we do start a replacement tank project for your vehicle, I will be sure to reach out.
Kind regards,
Teri Barry
Sales Supervisor
P: 530-893-5209 x 380
thomas5853
Fort Benning
Hemi 6.4L
Look at tankandbarrel.com
They sell aux tanks you can mount in your bed.
tron67j
Maryland
First auxiliary gasoline tank I have seen that solves the gravity feed problem.
Doug Ram
Central NY, AKA Upstate NY
Eco Diesel _3.0
I guess this makes me glad I went with the EcoDiesel 3.0 with the 33 gallon tank on my 1500. Range when towing the 6500 lb travel trailer is about 350 to 400 miles.
n8r_
Philly
Thanks for the info. Submitted my request.
Bldrinker
interesting comment.
Seems like an apples to oranges comparison. If We cut our trailers in half We could probably get a bit better mileage. And not need a larger fuel tank.
Willie Mosher
Las Vegas Nevada
6.4 gas
Back about mid 2019 Ram was offered
A ? 48 ? gallon tank for long bed 2500
6.4 gasoline. I tried researching to see if
Could backdate it to 2018 long bed
6.4 gases, but never come w full part
Number. But tank we’re about $1300
An not sure if software would tank the larger tank,
as most you guy know,
gas tank an Diesel
Are different and not compatible,
Unsafe used a Diesel transfer tank for gasoline.
sam darakjy
wilmington nc
2018 Tradesman Crew Cab 4x4
Speaking of gas tank size on 2018 2500. What is the actual size?My specs say 31 gallons but i have never been able to reach that number even close to empty with light on.
sandawilliams
Pueblo West, Co.
6.4 hemi
gas tank an Diesel
I ordered my 2021 HD with the 50 gallon tank. Only 300.00 charge. Fastastic to get 800+ mile range empty.
Ghstrdr95
