SouthTexan
- Joined
- Jan 24, 2015
- Posts
- 2,149
- Reaction score
- 1,305
- Ram Year
- 2014
- Engine
- 408 CTD
Dang man, chill out. He didn't mean you specifically. 20's aren't useless in offloading either bud. COPS racing team has 20's on their Trophy truck, which will beat anything you and your buddies do at moab.
A Trophy Truck is a different kind of off roading than what we are talking about here. TWilliams posted that he wanted a 2500 for it's straight (live) axle which is for slow speed off roading which is also what I do. I would recommend that you learn the difference between slow-speed off roading and high-speed off roading of a trophy truck. Also, look into why 20s are not the appropriate rim size for a true slow speed off roading truck. I will give you a hint, it has to do with traction.
yes a lift helps. It gives you more ground clearance, kind why I ruined my bumper, stock Rams are too low.
This is false, even if you lift your truck and nothing else, you will still have the same ground clearance at your axles. Lifts are mainly done for two reasons in a true off road vehicle. To fit larger tires and to increase your break over, approach, and departure angles. Too high of a lift will raise the center of gravity of a vehicle to a point at which it does more harm than good off road. Take a look at the Power Wagon and where it can go while being the same height and same sized tires as the regular 4x4 2500s. So that should tell you right there that a lift is not needed to be able to take you everywhere you are willing to take your truck. It also shows you that most that do lift their trucks do so for the looks to pose as an off roader rather than it being for any kind of benefit off road since the stock height would have been fine. If one really wanted to make their truck better off road then they would have upgraded the differentials to lockers and the coil springs to ones with a linear spring rate like what is found on the Power Wagon.
