Sychowski
Hi all. My 2013 1500 with 130k miles just went into 4th gear limp mode and shift hard into forward and reverse. First codes were P0750 and P0882 pointing at the solenoid. I checked the whole truck over. I swapped the relays around to see if that helped. Now I'm getting P0750 P0883 and P0562. I have found one of the 20 or so pin "waterproof" connectors by the passenger firewall with water in it and cleaned it up. Since some of the codes could be a wiring thing, do folks think it's time for a solenoid or more wire inspection? My backup sensors and keyless entry also don't work and I suspect electrical for them. Problem is I know I can do the solenoid myself
Thanks
Thanks
