Hemi395
- Mar 18, 2013
- 8,989
- 15,672
- Location
- Cape Cod MA
- 2013
- 5.7 Hemi
Yup sounds like the separator plate and/or the solenoid packIt started a while back with P2704 Transmission Friction Element E... Dropped the pan, everything looked normal. Research pointed at either valve body or something internal. Avoided it mostly by driving in tow/haul mode afterwards.
Then would get P0868 Trans Fluid Pressure Low intermittently. Would normally only happen if I was bagging on it. Would clear itself usually, and I just chalked it up to my aftermarket converter.
Then most recently P0740 Torque Converter Clutch Solenoid Circuit Open. Got the P0868 with this one as well so I'm hoping the P0740 was triggered by the P0868. Pulled the sonnax line pressure booster shortly and haven't had issues after.
If I still get them after all of this I will probably need to pull the trans.
