Why adjustable control arms, all he needs is the carrier bearing spacer kit no need for the adjustable arms ... although I have the core 4x4 adjustable arms I didn't need to adjust them to dial my pinion angles ....You’re going to need adjustable control arms to dial that angle in. I’m sure most trucks are good and you are one of the few that needs The pinion angle dialed in.
His pinion angle is off dropping the driveshaft won’t fox that angle. I’m wondering if the springs are sitting properlyWhy adjustable control arms, all he needs is the carrier bearing spacer kit no need for the adjustable arms ... although I have the core 4x4 adjustable arms I didn't need to adjust them to dial my pinion angles ....
Didn't he say they cut those springs? That might be the issue then ...His pinion angle is off dropping the driveshaft won’t fox that angle. I’m wondering if the springs are sitting properly
Something is wonky under thereDidn't he say they cut those springs? That might be the issue then ...
Just get the carrier bearing kit !!!!! lol .....So - called this morning, said it was vibrating at low speed and 50-60. He said he didn’t cut the springs, Maybe I misunderstood (totally possible). He suggested I drive it for another week or so, see if it settles in. If not, bring it back, to see if the driveshaft needs to be adjusted with shims. But he will fix it
Can’t shim a coil spring truck only leaf spring trucks. A Carrier bearing drop is cheap enough to try. You can do that in your driveway (I don’t think that is your fix but it surely will not hurt)So - called this morning, said it was vibrating at low speed and 50-60. He said he didn’t cut the springs, Maybe I misunderstood (totally possible). He suggested I drive it for another week or so, see if it settles in. If not, bring it back, to see if the driveshaft needs to be adjusted with shims. But he will fix it
And yes, the carrier bearing kit will fix that angle, that's how mine was before I installed it on my truck .... it drops the driveshaft a couple of inches I can get the exact measurements if you want ...His pinion angle is off dropping the driveshaft won’t fox that angle. I’m wondering if the springs are sitting properly
You definitely need to line all that up. Tranny to differential should be a straight line.I just had a 7” Maxtrac lift installed on my 2021 RWD Bighorn, I have a 2 piece driveshaft (quad cab, 6’4” bed). Do I need the carrier bearing spacer/drop kit? It wasn’t an option to order from Maxtrac for my model year, but I can order it for the older year (should fit mine) or order from Zone for my year.
I reached out to Maxtrac via email, they claim it’s not necessary for the 19 and newer model year. However…there is noticeably more vibration than pre install (when there was none), specifically between 52-58 mph, maybe this is what’s causing it?
I think it might be the shadows making it look wacky. The one picture is looks like the carrier drop would be my first tryOk, hopefully these show the driveshaft to diff angle better?
View attachment 487987View attachment 487988View attachment 487989
Looking at the first pic it looks like it is using stock control arms and no relocation brackets? With a 7” lift? That would tell me the axle must be twisted up wrong. Looking at the 3rd pic, its hard to tell but it looks like the axle pad is definitely twisted funky from the vertical plane of the coil spring, yet making that straighter would make the pinion angle even worse.Ok, hopefully these show the driveshaft to diff angle better?
I went back and looked at this pic…and i have to ask, is the driveshaft flange tight/flat up against the pinion flange? It looks like it isnt, and maybe the bolts are loose.Agreed - I’m not going to suggest anything at all, other than say theres a vibration…. I saw that fluid, too, but I don’t know if its related? I haven’t had any fluids changed, at all, other than an oil change about 5k miles ago (only 10k miles on the truck). It would be a strange coincidence, since there was no vibration when I drove it in and dropped it off, though. There is also moisture on other areas of the differential, so may have just run through a puddle when I was out running errands earlier That morning. (And ive Never seen any drips/stains on the driveway). Will check it this morning, to be sure
