- Joined
- Jan 17, 2016
- Posts
- 23,632
- Reaction score
- 54,263
- Ram Year
- 14 Sport
- Engine
- 5.7
Going by what the HD 2500 5th Gen guys with the 6.4/8 speed combo are saying ,it sures looks like the 8 speed transmission runs at a alot lower temp in a 2500 then it does in a 1500.The guys are reporting temps right around 160'ish even when towing with the HD 8 speed.I haven't dug into the HD 8 speeds enough to know if they still call for the same ZF 8/9 speed fluid the 1500's call for,if they use the same fluid though,it sure makes you wonder why the big temp differance,and if it might be beneficial to look into one of the aftermarket kits that deletes the heater assembly and thermostat on the 1500's 8 speed
