I wasn't meaning with just a hemi that you may want to do more than called for, I understand why some here use extra caution and pay particular attention to the Hemi's known failure point. There are others that exceed recommendations for reasons other than the lifters or cam issues as well. I had no clue they had this issue when I got it but I already planned to run the best oils and filters as I do in all my trucks. So in my mind the hemi tick isn't relevant unless I get it down the road and I'll know I did everything I could to prevent it including the fuel.
Just like my tundra I changed it at 5k vs 10k and will do the same thing on this Ram, when the oil life monitor hits 50% and or 5k miles which ever comes first I'll change it. I hope to hit the 5 k before the 50% and somewhat clean oil comes out.
This Ram has had 2 oil changes in 6000 miles, dealer changed it at 5k when I got it (demo) and I switched it over to PUP, as recommended 500 miles later.
Regardless of any historical failures in any of my vehicles I have always been aggressive with my oil change intervals and the use of high quality lubricates, filters and fuels is important to me. I don't stop at good oil, I believe the fuel is just as important part of the equation.
I feel the quality of fuel you use indeed helps the engine just like good quality oil does. High quality "plus" fuel is more than 2 octane points, it has additional cleaners and additives just like the good oils we use, that help the internal health of the engine as well, all worth the extra cost.
The point was, we will exceed factory recommendations in some areas and then not even use the recommended fuel. I'm concerned with the longevity and performance of my truck, not just one know failure point, so I'll use the recommended or better level of lubricants, filters and fuel.
