A LED bulb ?
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I ordered a set of 921 LED for the reverse lights ,and if I like they want to do the third Brake light /Cargo light.
When I tested the reverse light with the 194 LED I had I did not get a code so I should be OK with the 921 LED's.
BUT will I throw a code if I also do the third brake light ?
And from what I have read I sould got with RED LED's for the brake lights as white Leds bleach out a lot of the Red lens ?
Anyone have a issue with LED'S in the third brake light ?\
Thanks
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Lazfit leds. Zero issues. 3rd brake light, cargo lights, reverse lights, interior dome light. All work flawlessly and are bright.
Thanks. I ordered the AUXITO and have some Lazfits in the cab and If I remember some Auxito interior leds as well,
Good to know I should be good to go :)
In the third brake light did yo use the Red bulb or the white ?
caulk04
Supporting Vendor
You won't get a check engine light, but there will likely be a code stored in the system. Doesn't matter, the code is only there for troubleshooting the circuit.
I recommend matching the LED to the lens color.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks
Badger 13
North Idaho
2013 Dodge Ram 1500
I have no issues whatsoever with my LED (red) in the 3rd brake light housing. Also added LED's to the rear bed lights as well with no issues. Truck is a 2013.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks good to hear ! I have a 2015 . I will do a before and after picture. Extra lighting will be nice !
kero937
North carolina
Not nagging at you but I’m wondering if you had success with the LED swap? I just got my 2015 and have learned how picky this thing is when changing lights. If you have pics or any helpful tips changing out lights, I’d love to hear!
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Not a problem
,My 2015 is doing well with the LED'S
No LED headlights !
Only way to get info is ask :)
I put the 921 LED's in the reverse lights,and third brake lights,
A red LED in the third brake light as I was told the white LED'S could bleach out some of the red color and make it a bit lighter red, So went RED
Interior Did the map and dome lights and the glove box light
No Codes or issues just better light !
Tha 194 bulbs and dome lights (forgot the bulb size ) were 6k on the light spectrum so a very mild bluish tone ! I think 5k is pure white
As for tips You Tube is a good place to look that is what I did
To change tail light bulb to need a T 25 Torx bit or screw driver. Screws tail gate side of lights. slowly pull straight back and there are 2 plastic clips helping the light stay on !
For the map and dome lights a tiny pry tool is used , Again You Tube Videos will show you the tricks to remove covers and tail light
Treburkulosis
Glorified Car Washer
Haslet, TX
Looks great @Rado I did not have any issues with my third brake light. It was always turn signals. I finally got all of that worked out.
Phillyrube
Flatistan
Roger that, white LED will turn the brakelights pink. Ok on taillight mode. I threw dieselleds in the rear. Great backup lights, no real difference in brake lights. So save your money.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I want to do the Brake lights/Turn Signals with just a bulb, So that will be next, I just purchased Coverking seat covers and hearing aids this month so cash is tight lol
Treburkulosis
Haslet, TX
I understand that. I mine is fully LED converted. I like it a lot. My fog light finally burnt out after 5 years lol.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I have Quad Headlights .
Are yours Quads or Projectors ?
And what Bulb bid you use ?
Thanks
kero937
North carolina
Not a problem
No LED headlights !
Great info, thank you for taking the time and thank you for your service! The interior lights are next on my list, for sure.
Rado
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thank You
Your Welcome happy to be of some help ! I have learned a lot about my RAM on this site :)
These help show the tricks to remove the lens cover with out breakin gthe plastic tabs ad how to pull the 194 bulb out of the map light which is a pain lol . I ended up with a pair of duck bill plyers with duck tape on the bills so it woult stick to the bulb as you carefully pinch , You will figure out what works for you .
