ABS Module Replacement Questions
osprey92
I've decided to take the plunge and buy a used ABS module. After watching several videos of the replacement procedure, I have a few questions:
1. Is it true that you cannot write your current VIN to a used ABS module? If true, what issues does this cause?
2. It seems a first approach might be to swap circuit boards before removing the entire module. If I only swap boards, I should NOT need to bleed the system. Correct?
TIA
