Accessory Switches -Where????
flintstone15
Guaynabo
Hello all! Took delivery of a 2020 Rebel, ordered bumpers and lights. Now I am wondering where to install the light switches in an OCD way like OEM as I had on my ‘18 Raptor.
Any ideas??
olyelr
Kewadin MI
Any ideas??
Maybe you can implement the OEM auxiliary switch setup into it? Otherwise, switchpros’s and the like are really nice alternatives.
Achyas
Kitchener Ontario
I've seen someone have a bracket 3D printed that allowed them to mount switches into the factory sunglasses holder. I'm not sure if that was a 4th or 5th gen but should work if you have access to a 3D printer.
I have also seen an sPOD installed in a 5th gen rebel just above the dome light in the headliner, but that looks like it will only work if you don't have the sunroof.
Both looked completely factory and would make wiring clean as everything can be run under the headliner.
olyelr
Kewadin MI
Thanks olyelr, is this an OEM part? My 2020 does not have those. Any help will be appreciated
yes, that is an oem setup. Not all trucks have it... but its an option on some. Im sure with some work, you could buy the switch and use it for accessories.
Baron 187
USA
Mine is a 2018, so I know that’s not much help.... but I put my Aux switches in the headliner
I know not much help with a 2018 and no sunroof, but at least you can get an idea of what it might look like
noraa73
