eric wright
Maybe a dumb question can you add 4wd auto to a standard 4wd truck
If you're talking about the 4th gen 1500 trucks you definitely would want to do your homework before you decided to replace your non auto system with the auto. The non auto 44-45 system is is a direct drive system. When you put your truck in 4WD its locked in 4WD. The 44-44 auto system never actually locks into 4WD no matter what selection you change the dial too. It's a clutch activated system that has to detect rear wheel spin before it engages the front differential. They are known to not be nearly as durable as the 44-45 you currently have and have been known to overheat and fry the clutches if pressed to hard in some conditions. This is why the 4th gen Rebel plus the Outdoorsman are equipped with the non auto transfer case. Long story short yes you can change it by building a conversion harness and enabling the correct codes in the BCM and installing a 44-44 transfer case but most people are going the other direction. You can search YouTube and find videos people have posted showing the front tires not even spinning in snow and ice even the truck says its in 4WD lock.Maybe a dumb question can you add 4wd auto to a standard 4wd truck
My truck came with it. If all you're doing is highways and no serious stuff the auto will be more convenient. If you like off-roading and actual traction without too much electronic interference the t case you have now is best.Brandon are you happy with the upgrade? Is it worth it?
Unless the truck is highly modified or has some other sentimental value, a trade in for a higher trim level with the 44-44 is most logical.
The auto case is fantastic for people who know how to use it as designed. Rain, sand, mud, snow, and even perfect dry conditions the 4Auto does it all without binding up.
There’s a reason base model trucks get the simple cheap case that needs buttons pushed between conditions, because it gives them a little sense of comfort since they don’t have any other features.
Gen 4 Outdoorsman trim disagrees. It’s simple marketing. Your average buyer of high trim levels isn’t putting it in fleet or off rod service.
Same point could be could be argued that the 44-45 works fantastic for people who actually know how to use four wheel drive, not an AWD variant. But I come from manual locking hubs and syncroless stick shifts.
I would have no beef with the 44-44 if it was 100% clutch apply on 4hi/lo. Watched many a GM auto t-case get burnt due to less than 100% clutch apply in 4hi with constant use on logging roads.
The average daily driver will never notice the 44-44 not doing 100% clutch apply, but I notice it immediately in 6” plus snow.
Agree, use as designed and marketed. Outdoorsman and Rebel are off-road intended trucks, making the old school feel manly having to stop and “lock ‘em up” aka push a button which switches an electronic solenoid.
Or, “It can’t be tough without a lever shifter.”
Amsoil SS in my case gives me confidence with 4 auto in leaving a lot of stoplights.
My truck doesn't bind up or chirp the tires if I'm in 4 Wheel Drive. I would have to be on dry pavement turned pretty much lock to lock to have that happen and obviously I don't need to put it in 4 Wheel Drive on dry pavement. The only time I might do that is when I'm launching my boat and I've never had a problem with it then either. It works flawlessly. In my opinion they put the 44-44 auto unit it the higher trim levels because they know they will rarely be used for much more than occasional snow or icy conditions which is fine. To each his own but saying a transfer case that is stronger and works better is (cheap) makes no sense. The reason they put the 44-45 in the Rebel and the Outdoorsman which are both higher trim level trucks that are more geared to off road use is simply because they are more robust and actually are a true locking system. As far as having buttons to push for different conditions making people with the 44-45 transfer case feel better statement, In reality the buttons on the 44-44 auto trucks are the ones that actually don't do anything. There is a reason people are modifying their 44-44 transfer cases to actually lock the clutches in 4 Low and 4 High and there is a reason many people have replaced them with the 44-45. It's not a cheap transfer case as you suggest. It's actually much stronger than the 44-44 and works well. If I'm driving in heavy snow or icy conditions I like knowing my truck isn't going to have to actually lose traction in order for the transfer case to kick in and its actually going to work. Just my two cents but pulling the 44-45 transfer case and installing a 44-44 transfer case in my truck would be the last thing I would do. I bought my truck specifically with the 44-45 transfer case for that reason.Unless the truck is highly modified or has some other sentimental value, a trade in for a higher trim level with the 44-44 is most logical.
Sent from my SM-G981U1 using Tapatalk
