Adjusting Bilstein 5100s
CruzRam14
I had a set of Bilstein 5100s installed a few months ago. I want to bring them down a setting as the front is sitting a bit higher than the back. Will this require taking them completely off again? Anyone know what the easiest way to adjust them is?
AustinB
Banned
San Diego, Left Coast
Its pretty much the same process as doing the swap from stock to the bils.
Easier to just put spacers in the rear.
C
CruzRam14
Any recommedations on the rear spacers?
rtm03862iq
NJ
I'm sort of in the same boat. Probably just gonna lower the Bils
sriley531
Ohio
This^^^
I used 3/4" top gun spacers. Easy to install and work perfectly.
Scgirardi
Rear coil spacers 60bucks and 20minutes in f your time. Is much easier then doing the bils all over. Not to mention the cost of an alignment
