Advice needed!
TX-Ghost
Conroe,TX
OK so I’m needing to replace a couple wiring harnesses and was wanting to know if anyone has done the same and where I can order them.
1) I pulled my fog lights out as they were not working so I was planning on replacing them and noticed one of the harnesses must have been grounding out and had started to melt where they plug in to the DS fog light assembly. Looking for either OEM or LED compatible as I’m not 100% sure which direction I’ll go yet.
2) The wiring harnesses for my headlights apparently got “ customized” from the previous owner, so I’m wanting to find out about replacing those as well. Same thing OEM or LED compatible.
Bigskyroadglide
Moderator
Member Relations Specialist
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Connect with Benny @AllMoparParts.com a forum vendor, provide your vin and ask him if the harnesses are available. He can sell you new ones. Or You may be looking at a salvage yard opportunity
turkeybird56
Central Texas
Hemi 5.7, Non E Torque
^^^ DITTO ^^^ But OP be aware, not the cheapest stuff to get.
PdPuNOme
Jersey
if it was me, I would be searching ebay for a used harness to make it simple rather than attempting repairs, cost effective and time effective. The front clip harness will look similar to this where it has the headlights and fogs coupled in with a few others like the hood latch etc.
diymirage
Banned
What's that grim fella ?
He might also be able to make you a harness that fits your needs
But, if all youre doing is replacing wiring that came from the factory, I would go with junkyard parts (Iether in person or online)
